VBA Macro - Traverse Assembly - Get Part "Description", "Material" & "iProperties"
isocam
isocam
Can anybody help?
I have asked this question before but I do not know how to solve it.
I have the following VBA macro....
Public Sub TraverseAssembly()
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = ThisApplication.ActiveDocument
    msgbox(oAsmDoc.DisplayName)
    Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1)
End Sub
Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer)
    Dim oOcc As ComponentOccurrence
    For Each oOcc In Occurrences
        Msgbox(oOcc.Name)
        If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then Call TraverseAssembly(oOcc.SubOccurrences, Level + 1)
    Next
End Sub
Is it possible to get the "DESCRIPTION", "MATERIAL" & "CUSTOM PROPERTIES" using oOcc?
For Example,
Msgbox(oOcc.Description)
Msgbox(oOcc.Material)
Msgbox(oOcc.  iProperties File Sub-Type)
Etc.
Many thanks in advance!
Darren
Michael.Navara
I recommend you to focus on iLogic or VB.NET instead of VBA. But the code can look similar.
iLogic sample
Sub Main()
    Dim asm As AssemblyDocument = ThisDoc.Document
    'Container for result string
    result = New StringBuilder()
    result.AppendLine(asm.DisplayName)
    Dim occurrences As ComponentOccurrences = asm.ComponentDefinition.Occurrences
    TraverseAssembly(occurrences, 0)
    Logger.Debug(result.ToString())
End Sub
Dim result As New StringBuilder
Private Sub TraverseAssembly(occurrences As ComponentOccurrences, level As Integer)
    For Each occurrence As ComponentOccurrence In occurrences
        Dim occDef As ComponentDefinition = occurrence.Definition
        Dim displayName As String
        Dim description As String
        Dim material As String
        'Occurrence is part
        Dim part As PartDocument = TryCast(occDef.Document, PartDocument)
        If part IsNot Nothing Then
            displayName = part.DisplayName
            description = part.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}")("Description").Value.ToString()
            material = part.ActiveMaterial.DisplayName
            'TODO: Do anything you want with variable 'part'
        'Occurrence is assembly
        Dim asm As AssemblyDocument = TryCast(occDef.Document, AssemblyDocument)
        If asm IsNot Nothing Then
            displayName = asm.DisplayName
            description = asm.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}")("Description").Value.ToString()
            material = "" ' Assembly hasn't material
            'TODO: Do anything you want with variable 'asm'
        'Append result
        result.AppendLine(String.Join(";",
                          New String(" ", level),
                          displayName,
                          description,
                          material
        'Recursive call if necessary
        Dim subOccurrences  = occurrence.SubOccurrences
        If (subOccurrences IsNot Nothing And subOccurrences.Count > 0) Then
            TraverseAssembly(subOccurrences, level + 1)
    Next
End Sub
VBA sample
Sub Main()
    Set asm = ThisApplication.ActiveDocument
    Dim result As New Collection
    Call result.Add(asm.displayName)
    Set occurrences = asm.ComponentDefinition.occurrences
    Call TraverseAssembly(occurrences, 0, result)
    For Each line In result
    Debug.Print line
    Next
End Sub
Private Sub TraverseAssembly(occurrences As ComponentOccurrences, level As Integer, result As Collection)
    Dim occurrence As ComponentOccurrence
    For Each occurrence In occurrences
        Set occDef = occurrence.Definition
        'Occurrence is part
        If occDef.Document.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
            Set part = occDef.Document
            displayName = part.displayName
            description = part.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}")("Description").value
            material = part.ActiveMaterial.displayName
        If occDef.Document.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
            Set asm = occDef.Document
            displayName = asm.displayName
            description = asm.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}")("Description").value
        'Append result
        result.Add (String(level, " ") & ";" & _
                    displayName & ";" & _
                    description & ";" & _
                    material)
        Dim subOccurrences As ComponentOccurrences
        Set subOccurrences = occurrence.subOccurrences
         If (Not subOccurrences Is Nothing And subOccurrences.Count > 0) Then
            Call TraverseAssembly(subOccurrences, level + 1, result)
    Next
End Sub
AndrewHumiston
Good morning,
here is a quick vba to get you started, if you want it to display 'part' or 'assemlby' you can use ".documenttype" instead of ".displayname" but you'll need to run a 'case' statement to sort out the enum's as they display as numerical value. Keep in mind when you are looking for document properties they can get mixed around when you are diving into where they are in an assembly, you have to access the specific component, then find the 'reference' file that is the parent of that component, this allows you to get the actual value of the specific property incase some 'funny business' has happened with the instance.
Sub GetOcciProps()
Dim oActiveDoc As AssemblyDocument
Set oActiveDoc = ThisApplication.ActiveDocument
For Each oOcc In oActiveDoc.ComponentDefinition.Occurrences
MsgBox (oOcc.ReferencedDocumentDescriptor.ReferencedDocument.PropertySets.Item("Design Tracking Properties").Item("Description").Value)
MsgBox (oOcc.ReferencedDocumentDescriptor.ReferencedDocument.PropertySets.Item("Design Tracking Properties").Item("Material").Value)
MsgBox (oOcc.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName)
Next
End Sub
i hope this helps, let me know if you have any further questions or ideas!
please accept this as a solution if it has solved your issue!
WCrihfield
Hi @isocamIn iLogic, the simplest way to get/set material directly using 'oOcc' (representing a ComponentOccurrence object) is with a line of code like the following.
get example:
Dim sMaterial As String = iProperties.Material(oOcc.Name)
 set example:
iProperties.Material(oOcc.Name) = "Steel"
As for the others, which are iProperties, you can use the following in iLogic (not in VBA):
iProperties.Value(oOcc.Name, "Project", "Description") = "My Description"
However, we can not use any of those iLogic 'shortcuts' in VBA.
And no, there is no 'direct' way to access iProperties from 'oOcc', because iProperties are stored in Document objects, not in ComponentOccurrence objects.  You would need to dig into the 'oOcc' object's properties to find the Document object it is referencing, then dig into that Document to access its iProperties.  There are two routes to do that:
oOcc.Definition.Document.PropertySets.Item().Item().Value
or...
oOcc.ReferencedDocumentDescriptor.ReferencedDocument.PropertySets.Item().Item().Value
Tip:  If the component is suppressed, then accessing the oOcc.Definition property will throw an error.
Tip:  If the component is Virtual (for BOM purposes only), then it will not have a Document, and you would have to access its iProperties in a different way.
For example:
oOcc.Definition.PropertySets...and so on (no Document in there).
Tip:  The oOcc.Definition.Document property gives you a generic Object type value, instead of a generic Document value type, so you may want to create a Document type variable, then set its value with oOcc.Definition.Document first, then use that to access its iProperties.
Tip:  Same for oOcc.ReferencedDocumentDescriptor.ReferencedDocument property...it gives you an Object, not Document type, so use same strategy there.
Wesley Crihfield
(Not an Autodesk Employee)
