VBA Macro to Toggle Enabled / Disabled Component
Can someone provide a macro that will allow me to, after selecting a part or component, toggle whether it is enabled or disabled.  I would like this so that I can assign a keyboard shortcut to the macro, and then quickly enable/disable parts in an assembly.
Thank you for your help.
YuhanZhang
Here is the macro:
Sub ToggleOccuEnabled()
    Dim oDoc As Document
    Set oDoc = ThisApplication.ActiveDocument
    If oDoc.DocumentType = kAssemblyDocumentObject Then
        Dim oAssy As AssemblyDocument
        Set oAssy = oDoc
        Dim oDef As AssemblyComponentDefinition
        Set oDef = oAssy.ComponentDefinition
        If oAssy.SelectSet.Count <> 0 Then
            Dim oObj As Object
            Set oObj = oAssy.SelectSet(1)
            If TypeName(oObj) = "ComponentOccurrence" Then
                Dim oOccu As ComponentOccurrence
                Set oOccu = oObj
                ' Toggle the Enabled
                oOccu.Enabled = Not (oOccu.Enabled)
    End
End Sub
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
I copied the macro provided into my vba module, and then set a keyboard shortcut for the ToggleOccuEnabled macro.  It works like a charm.  Thank you.
