VBA Macro - Create a PDF File from a IDW File
isocam
isocam
Can anybody help???
Before I run this on Autodesk Inventor 2012, can anybody see any possible problems that I might have with the following VBA macro code?
Set Doc = ThisApplication.ActiveDocument
Call Doc.SaveAs("C:\Test.pdf", True)
All I want to do is to create a PDF file, automatically, from a IDW file without going through a PDF Printer
Many thanks in advance!!!
isocam
Try This!!!
    Dim Doc As Document
    PdfFileName = DrawingFilePath & PartNumber & ".pdf"
    Call Doc.SaveAs(PdfFileName, True)
xiaodong_liang
Autodesk Support
Autodesk Support
To publish the document to a PDF, two options:
use PrintManager.
Dim oPM as PrintManager
Set oPM = oDoc.PrintManger
oPM.Printer = "Adobe PDF"
oPM.PrinteToFile  "c:\test.pdf"
using TranslatorAddin
Please firstly have a look at the topic "TranslatorAddin" in the API help document. The following code sample is for your reference. Although it is written in VBA, it would need little effort to translate to C++. Please let me know if you have any difficulty.
Sub test()
Dim addins As ApplicationAddIns
Set addins = app.ApplicationAddIns
Dim oPDFAddin As TranslatorAddIn
'Set oPDFAddin = ThisApplication.ApplicationAddIns.ItemById ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
Dim oContext As TranslationContext
Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = kFileBrowseIOMechanism
' Create a nameValueMap
Dim oOptions As NameValueMap
Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
' Check
Debug.Print oPDFAddin.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions)
If oPDFAddin.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
'this setting has no effect
' oOptions.Value("All_Color_AS_Black") = "False" 'True
'change to a path on your system
oDataMedium.FileName = "C:\ExportPDF.pdf"
' Publish document
Call oPDFAddin.SaveCopyAs(ThisDocument, oContext, oOptions, oDataMedium)
End Sub
