VBA FileDialog object - problem with InitialDirectory
Message 1 of 25
I need (in VBA makro) save file to given folder.
I want to do it with FileDialog object but I can't set folder in dialog windows with InitialDirectory method.
There is always last used folder in dialog window.
Does anybody know why InitialDirectory doesn't work?
{code}
Call ThisApplication.CreateFileDialog(oFileDlg)
oFileDlg.InitialDirectory = "C:\temp"
oFileDlg.ShowSave
{code}
Replies (24)
Message 2 of 25
I have the same problem. And it is odd becuase it is only with the Save, the Open works fine.
For me the Save always goes to my default inventor last save directory.
Any input would be appreciated.
Message 3 of 25
Could you let me know which version of Inventor (and service pack) each of
you is seeing this issue with?
thanks,
Sanjay-
Message 4 of 25
I use Inventor 2009, SP 2 but now I found solution.
Path must be written in FileName attribut
{code}
oFileDlg.InitialDirectory = 'C:\temp'
oFileDlg.FileName = 'C:\temp\example.ipt'
oFileDlg.ShowSave
{code}
Message 5 of 25
Inventor 2009 Service Pack 1
(didn't know 2 was out ill have to update)
That filename trick worked my only problem is that it fills the Filename property which is what i use to check for valid selections. ill be able to work around that though in my error checking to prevent a million copies of that default name being created.
thanks
EDIT:
i used this code since my initial directory changes from time to time....
{code}
newPath.DialogTitle = "Select Location for New File"
newPath.InitialDirectory = ThisApplication.FileLocations.Workspace
newPath.FileName = newPath.InitialDirectory + "\.dwg"
newPath.CancelError = True
{code}
this allows an invalid save with an error and doesn't default your directory to one spot. Edited by: ENDCad on Sep 9, 2009 4:02 PM
Message 6 of 25
I checked and unfortunately, this was a known issue in Inventor 2009.
Providing the full path in the filename is the only workaround, as you've
discovered. This issue is fixed in Inventor 2010 and doesn't need a filename
specification.
Sanjay-
Message 7 of 25
specification.
Sanjay,
I am a user of Inventor 2010 SP1 and unfortunately this issue is NOT solved yet!!!!!!!!!!!!!!
I have the same problems with the "Initial Directory"
How can i solve this?
thx
bjorn
Message 8 of 25
2013 & it seems this thing is still sneaking around.. or???
Message 9 of 25
philippe.leefsma
I'm testing that under 2013 SP1.1 Update 2 and it seems to work correctly:
Public Sub CreateFileDialog()
    Dim App As Inventor.Application
    Set App = ThisApplication
    Dim dlg As FileDialog
    Call App.CreateFileDialog(dlg)
    dlg.InitialDirectory = "C:\"
    dlg.filter = "Inventor Files (*.ipt)|*.ipt | Assembly File (*.iam)|*.iam"
    dlg.DialogTitle = "Save Native"
    dlg.ShowSave
End Sub
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Message 10 of 25
Doesn´t work for me in C# & when I copy paste your code directly in the VBA editor  & run I end up in my vault project folder..  e.g. not C:\".  I´m on the same build.
Message 11 of 25
xiaodong_liang
Autodesk Support
Autodesk Support
there is a C# demo code in the API help reference. Hope it helps you to figure out the problem:
public void TestFileDialog()
    Application oApp = ThisApplication;
    // Create a new FileDialog object.
    FileDialog oFileDlg;
    oApp.CreateFileDialog(out(oFileDlg));
    // Define the filter to select part and assembly files or any file.
    oFileDlg.Filter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All Files (*.*)|*.*";
    // Define the part and assembly files filter to be the default filter.
    oFileDlg.FilterIndex = 1;
    // Set the title for the dialog.
    oFileDlg.DialogTitle = "Open File Test";
    // Set the initial directory that will be displayed in the dialog.
    oFileDlg.InitialDirectory = "C:/Temp";
    // Set the flag so an error will not be raised if the user clicks the Cancel button.
    oFileDlg.CancelError = false;
    // Show the open dialog.  The same procedure is also used for the Save dialog.
    // The commented code can be used for the Save dialog.
    oFileDlg.ShowOpen();
    // oFileDlg.ShowSave();
    System.Windows.Forms.MessageBox.Show("File " + oFileDlg.FileName + " was selected.", "Selected file");
Message 12 of 25
Yep.. That´s more or less the same code I used, but no cigar as mentioned earlier, Using the IV2009 workaround described in this thread, does the job so I´m long gone. I have a strong feeling the internal vaultclient is overriding oFileDlg.InitialDirectory.. Check it out  😉
Message 13 of 25
Workaround described in this thread doesn't work for an open file dialog. Anybody got a work around for an open file dialog? or an alternative method of calling an open file dialog box where the initial directory can be set??
Thx in advance
Message 14 of 25
xiaodong_liang
Autodesk Support
Autodesk Support
Hi ZX_Spectrum_48k ,
could you clarify what kind of problem you hit? I did not get a clue from the existing messages in the thread.
Message 15 of 25
The sample code in the 2014 help menu as reproduced below will not produce a file dialog box starting in c:\temp, instead the file dialog will display the last used folder.
Seems to have been an issue for a while ......................
Public Sub TestFileDialog() ' Create a new FileDialog object. Dim oFileDlg As FileDialog Call ThisApplication.CreateFileDialog(oFileDlg) ' Define the filter to select part and assembly files or any file. oFileDlg.Filter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All Files (*.*)|*.*" ' Define the part and assembly files filter to be the default filter. oFileDlg.FilterIndex = 1 ' Set the title for the dialog. oFileDlg.DialogTitle = "Open File Test" ' Set the initial directory that will be displayed in the dialog. oFileDlg.InitialDirectory = "C:\Temp" ' Set the flag so an error will be raised if the user clicks the Cancel button. oFileDlg.CancelError = True ' Show the open dialog. The same procedure is also used for the Save dialog. ' The commented code can be used for the Save dialog. On Error Resume Next oFileDlg.ShowOpen ' oFileDlg.ShowSave ' If an error was raised, the user clicked cancel, otherwise display the filename. If Err Then MsgBox "User cancelled out of dialog" ElseIf oFileDlg.FileName <> "" Then MsgBox "File " & oFileDlg.FileName & " was selected." End If End Sub
Message 16 of 25
adam.nagy
Autodesk Support
Autodesk Support
Strange. It seems to work for me and starts in whatever folder I set as InitialDirectory: http://www.screencast.com/t/w2K7yJ9q
Cheers,
Adam Nagy
Autodesk Platform Services
Message 17 of 25
jdkriek
*Make sure the directory actually exists and you have proper permissions*
 We had this issue recently and discovered if the directory doesn't exist it will simply use the last directory it succesfully hit.
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Message 18 of 25
Don't think thats the problem - I can get initial directory to behave if I have no inventor files open.
As soon as I have an inventor file open, always get the project folder regardless of what initial directory is set to.
Anyone else find the same thing??
Message 19 of 25
binuvarkey
We have the same problem in all 4 seats of Inventor Pro 2014.
oFileDlg.InitialDirectory settings are not honoured and the dialog opens with Workspace in focus. We have Vault 2014 Workgroup installed and signed in.
Message 20 of 25
binuvarkey
When the dialog opens in the Project Folder, if we browse to another directory from the dialog box and cancel the dialog or open the file, next time initialdirectory is set to the other directory we browsed to or opened file from.
