VBA failure Inventor 2023: AddByComponentDefinition will fails if the the ComponentDefinition object has Model States
christoph_stumpf
christoph_stumpf
Who could help me,
if you want to add an occurence in an Assembly an the "newdoc.ComponentDefinition" Object has Model States the following code get an error...
activeASS.ComponentDefinition.Occurrences.AddByComponentDefinition(newdoc.ComponentDefinition, oPositionMatrix)
The code work always if the "newdoc.ComponentDefinition" has no Model States. (Inventor 2023)
JelteDeJong
I expect that your object "activeASS" is not the factory document. (But a model state document). You might want to have a look at this post "Working with PropertySets and Model States"
Jelte de Jong
Blog: hjalte.nl - github.com
christoph_stumpf
the activeASS is not a factory document, is an standard assembly document.
In this document i will place a new part document which is an template. This template has Model states.
The routine run's since years, but now i have added to the template model states an then i get the error in VBA.
christoph_stumpf
No this don't help me.
The only thing i will do is to add an template File into an Assembly document, via AddByComponentDefinition.
It works since years without problems. But i have add to the template Model State definition. After that it don't work.
I don't add properties or other thinks in the moment, i only want to add the template.... so your link is not the solution.
