VBA Creating path from derived sketch block
Hi everyone.
I've got a problem with creating Path in Inventor VBA. I've created a source block definition in SourcePart.ipt, derived it in DestPart.ipt, placed this derived SketchBlockDefinition in Sketch3 and draw 3 extra lines. Now i want to add a SplitFeature with SplitTool as a Path of 3 lines, but first i need to create this Path. There is no problem with creating path from this 3 extra lines, but when i want to create path from lines that belongs to derived block - an error occurs.
Below is sample code (also included in attached file - DestPart.ipt). Try run it with DestPart.ipt as an active file. When Inventor is prompting for Selecting Sketch Entity first select one of 3 extra lines, macro ends with no errors. Then run it again, this time select one of 3 lines that belongs to SketchBlock - an error occurs.
When you try to add SplitFeature (Trim Solid) by UserInterface Button "Split" there is no problem with any set of 3 lines.
Sub CreatePathTest()
    Dim oPartDoc As Inventor.PartDocument
    Set oPartDoc = ThisApplication.ActiveDocument
    Dim oPickedSketchEntity As Inventor.SketchEntity
    Set oPickedSketchEntity = ThisApplication.CommandManager.Pick(kSketchCurveFilter, "Select Sketch Entity")
    Dim oNewPath As Inventor.Path
    Set oNewPath = oPartDoc.ComponentDefinition.Features.CreatePath(oPickedSketchEntity)
End Sub
My System is Windows 7 32bit/64bit, Inventor 2012
Thanks in advance for any help.
xiaodong_liang
Autodesk Support
Autodesk Support
This is an issue which has been logged:
SkBlock, Path: CreatePath and CreateSpecifiedPath doesn't work for sketch block curve.
And it exists in 2014 as well. Sorry if this is a bas news for you.
