VBA create sketch in assembly with reference to a part
Message 1 of 1
What I'm trying to do in VBA is to create a sketch at origin (XY - plane)  of each and every subassembly in the assembly.
I know that one way to do this is to create a plane by fixed method for each subassembly and then put a sketch on this plane.
But this way is unsatisfactory because I need the sketch to be "linked" to the subassembly...it means if the subassembly changes its position the sketch moves as well.
Is there any way how it can be done ? e.g. by using subassembly faces ?
Thanks a lot
Martin
Replies (0)
