VBA Create new text style for general note
pball
Mentor Mentor
pball
I'm wasting a lot of time trying to find or figure out how to create and apply a text style to a new note. I'm using the following code to create a new note but I can't get it to use a new text style so I can format it differently.
I would also accept if it's possible to add rotation in the styleoverride in the formattedtext of a note. I've tried adding it but it doesn't seem to affect anything unlike the fontsize which appears to work.
    Dim invDoc As Document
    Set invDoc = ThisApplication.ActiveDocument
    Dim stext As String
'The rotation override sadly does not seem to work at any value I've tried, other wise I'd just use this method stext = "<StyleOverride FontSize = '0.1524' Rotation = '90'>PRINTED: " & Now() & "<Br/>BY: " & ThisApplication.GeneralOptions.UserName & "</StyleOverride>" ' Set a reference to the GeneralNotes object Dim oGeneralNotes As GeneralNotes Set oGeneralNotes = invDoc.ActiveSheet.DrawingNotes.GeneralNotes Dim oTG As TransientGeometry Set oTG = ThisApplication.TransientGeometry Dim oGeneralNote As GeneralNote Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(0.3, 1.5), stext)
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
Owner2229
Try this:
Dim stext As String
stext = "<StyleOverride Font='ARIAL' FontSize = '0.1524' >PRINTED: " & Now() & "<Br/>BY: " & ThisApplication.GeneralOptions.UserName & "</StyleOverride>"
' Set the color of the note if needed
Dim oColor As Color
Set oColor =
ThisApplication.TransientObjects.CreateColor(128, 128, 128)
oGeneralNote.Color = oColor
' Set the rotation of the note in Radians
oGeneralNote.Rotation = 1.57
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
pball
Wow that is stupidly simple. Every example I've seen of creating a new note and altering it involved messing with styles. Thanks
Owner2229
You're welcomed Smiley Happy
Mike
