[VBA] Change position of existing Sketch Symbol and Parts List
amarcoc
Message 1 of 10
amarcoc
Hi.
How can I change position of existing Sketch Symbol and Parts List?
I created a macro to easely change Sheet Size, but I need to re-position Sketch Symbols and Parts List, but I couldn't do it.
Sketch Symbol Names are: "Tol Geral" and "Comentarios automaticos"
Thanks in advance!
Accepted solutions (3)
Replies (9)
Message 2 of 10
marcin_otręba
sketched symbol:
oSketchedSymbol = odraw.ActiveSheet.SketchedSymbols.Item(1)
oSketchedSymbol.Position = g_inventorApplication.TransientGeometry.CreatePoint2d(1, 1)
partlist:
Set opartslist = osheet.PartsLists(1)
opartslist.Position = g_inventorApplication.TransientGeometry.CreatePoint2d(1, 1)
Hi, maybe you want to vote my:
Ideas
or check my apps:
DrawingTools   View&ColoringTools   MRUFolders   auto-save-replace
Message 3 of 10
amarcoc
Thanks!
I did try, but couldnt make it work. Is that for VBA?
Please check attached errors.
Message 4 of 10
marcin_otręba
For vba you must  use set :
set oSketchedSymbol = odraw.ActiveSheet.SketchedSymbols.Item(1)
you didint set osheet:
Dim osheet As Sheet
Set osheet = Thisapplication.activedocument.ActiveSheet
Ideas
or check my apps:
Message 5 of 10
amarcoc
I still cant make it work 😞
Message 6 of 10
marcin_otręba
change g_inventorapplication to thisapplication.
Ideas
or check my apps:
Message 7 of 10
amarcoc
Thanks! That was it.
How can I know Part List height?
Message 8 of 10
marcin_otręba
Dim oprtl As PartsList
Set oprtl = Thisapplication.activedocument.ActiveSheet.PartsLists.item(1)
Dim height, width As Decimal
Set  width = (oprtl.RangeBox.MaxPoint.X - oprtl.RangeBox.MinPoint.X)*10
Set height=(oprtl.RangeBox.MaxPoint.Y - oprtl.RangeBox.MinPoint.Y)*10
Sorry it was logic. i corrected it.
Ideas
or check my apps:
Message 9 of 10
amarcoc
Thanks. It worked.
Last question:
How can I check Model Documentype (running same VBA macro from a drawing?). I want partlist code to run only if model is an assembly.
Thanks!!!
Message 10 of 10
marcin_otręba
odraw.ReferencedDocuments.Item(1).documenttype
Ideas
or check my apps:
