VBA Borderdefinition.Edit(sketch) fails
M.Zirk
M.Zirk
in an IDW I have some border definitions.
I try to access a borderdefinition sketch, but receive an error.
Because I get the names of the borderdefinitions in the IDW, the initialisation before must be ok.
This method cuses the error:
Call oBorderDef.Edit(oDrawingSketch)
Sub ChangeBorderDefinition()
'On Error GoTo Errorhandler
Dim oDrawingDoc As DrawingDocument
Dim oDrawingSketch As DrawingSketch
Dim oBorderDef As BorderDefinition
Set oDrawingDoc = ThisApplication.ActiveDocument
For Each oBorderDef In oDrawingDoc.BorderDefinitions
    Debug.Print oBorderDef.Name
Next oBorderDef
Exit Sub
Errorhandler:
    Debug.Print Err.Description
    Debug.Print Err.Number
End Sub
Any ideas what is going wrong?
Manfred
mateusz_baczewski
I believe this happens because, when you iterate through all frames, you end up trying to edit the default frame—which isn’t editable. That’s why you’re seeing an error. Below is a snippet of code that lets you edit a frame.
Sub main
	Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
	Dim oBorders As BorderDefinitions = oDoc.BorderDefinitions
	Dim oBorder As BorderDefinition = oBorders.Item(2)
	Dim oSheet As Sheet = oDoc.ActiveSheet
	Dim oDrawSketch As DrawingSketch
	oBorder.Edit(oDrawSketch)
End Sub
If you found it helpful, a "Like" would be much appreciated!
If this post solved your problem, please mark it as "Solution.".
M.Zirk
Hello  Mateusz,
thank you for your help.
Manfred
