VBA BOM export with excel template
ngocson8335
ngocson8335
Dear Expert,
I am using VB.Net to fill part's information to excel template. But something is wrong with my code.
BOM in inventor:
Relacing all components in sub-assembly 6
Private Sub btnExportExcel_Click(sender As Object, e As EventArgs) Handles btnExportExcel.Click
        invApp = Marshal.GetActiveObject("Inventor.Application")
        assemblyDoc = invApp.ActiveDocument
        Dim oTemplate As String = "C:\Users\ngocs\OneDrive\Documents\05-Personal Work\01_Test_Files\ExcelTemplates.xls"
        Dim oBOM As BOM = assemblyDoc.ComponentDefinition.BOM
        oBOM.StructuredViewFirstLevelOnly = False
        oBOM.StructuredViewEnabled = True
        Dim oBOMView As BOMView
        oBOMView = oBOM.BOMViews.Item("Structured")
        Dim oPartNumber As Inventor.Property = Nothing
        oPartNumber = assemblyDoc.PropertySets("Design Tracking Properties").Item("Part Number")
        Dim oPartNumProperty As String
        oPartNumProperty = oPartNumber.Value
        Dim xlApp As Object = CreateObject("Excel.Application")
        Dim xlwb As Object = xlApp.Workbooks.Open(oTemplate)
        Dim xlws As Object = xlwb.Worksheets(1)
        xlApp.Visible = True
        xlws.name = "Structured " & oPartNumProperty
        Dim oStartRow As Integer = 1
        Call QueryBOMRowProperties(oBOMView.BOMRows, xlApp, xlwb, xlws, oStartRow)
    End Sub
    Private Sub QueryBOMRowProperties(oBOMRows As BOMRowsEnumerator, ByVal xlApp As Object, ByVal xlwb As Object, ByVal xlws As Object, oStartRow As Integer)
        For i = 1 To oBOMRows.Count
            Dim oRow As BOMRow
            oRow = oBOMRows.Item(i)
            Dim oCompDef As ComponentDefinition
            oCompDef = oRow.ComponentDefinitions.Item(1)
            Dim oPartNumProperty As Inventor.Property
            If TypeOf oCompDef Is VirtualComponentDefinition Then
                oPartNumProperty = oCompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number")
                xlws.Cells(oStartRow, 1) = oRow.ItemNumber
                xlws.Cells(oStartRow, 2) = oPartNumProperty.Value
                xlws.Cells(oStartRow, 3) = oRow.ItemQuantity
                oStartRow = oStartRow + 1
            Else
                If Not oRow.ChildRows Is Nothing Then
                    Call QueryBOMRowProperties(oRow.ChildRows, xlApp, xlwb, xlws, oStartRow)
        Next
    End Sub
Please help me.
Many thanks.
Ngoc Son
Ngoc Son
Autodesk User
JamieVJohnson2
If statements are usually the bane of everybody's existence.  Yours is very interesting to me, you have 1 condition with 2 blocks.  The first block does not check for child rows, and the second block does.  Perhaps your condition is the wrong assumption.  Is it possible that row 6 (assembly) IS a VirtualComponentDefinition, and therefor not getting its children loaded?
            Else
It would be simpler to combine the code of the 2 blocks and only run the bottom check:
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
ngocson8335
Hi Mr.
 Is it possible that row 6 (assembly) IS a VirtualComponentDefinition, and therefore not getting its children loaded?
=> No it's not. It gets all value but when it runs to the sub 7 it overrides on the row of sub 6.
Please see my attached Video for more details.
Ngoc Son
Autodesk User
JamieVJohnson2
I see your real problem.  oStartRow.  You are expecting it to act as a single number reference for every use of it.  But it is actually only working as a temp reference for each run of Sub QueryBOMRowProperties.  So should be a simple fix... define it as ByRef oStartRow instead of ByVal (for VBA ByVal is default when you don't specify, but that changes later in VB.Net to ByRef as default)  ByRef will use the same one data pointer for EVERY call, and the row will add up, not add up-return-reset-and add up again.
ngocson8335
Hi Sir,
Thanks for your explanation. It's working well.
Thanks, thanks thanks, Sir.
Ngoc Son
Ngoc Son
Autodesk User
