VBA adding column to revision table
I've written some code which resizes/updates the active sheet's borders, title blocks, styles etc.
I'm having trouble with the revision table when resizing the sheet, our templates miss out a "GRID REF" column in A4 which is custom but already exists. When scaling down to A4 I can delete this column but cannot add it
    Set RevTable = invDoc.ActiveSheet.RevisionTables(1)
    If "A4" = SheetSize Then
        If RevTable.RevisionTableColumns.Count = 4 Then
        Else
            RevTable.RevisionTableColumns.Item(3).Delete
    Else
            RevTable.RevisionTableColumns.Add (kRevisionTableCustomProperty,,"GRID REF",3)
The add line does not work, it says it should equal an expression but what and why?
Another thing that I would like to do is resize the column widths if possible but this is less important.
Thank you in advance!
I have since made it work- but am still left with the problem of the width not being right!
Also, I am taking the new borders etc. from the default template which also has illogic rules in- how can I bring these into the new drawing? Is this even possible?
Curtis_Waguespack
Hi aliceloneragan,
There is an example of setting the column width at this link:
http://forums.autodesk.com/t5/inventor-customization/revision-table-collumn-width-change/m-p/6407387#M65030
I hope this helps.
Curtis
