VB Public variable of inventor app is not read from other subs.
JBEDsol
JBEDsol
So I start w/ this, I'm using VB.net through Visual studio
Imports System
Imports System.Type
Imports System.Activator
Imports System.Runtime.InteropServices
Imports Inventor
'Imports AutoCAD
Imports System.Windows.Forms
Module GlobalVariables
     Public _invApp As Inventor.Application
End Module
Then I added
Private Sub Get_Volumes_Click_1(sender As Object, e As EventArgs) Handles Get_Volumes.Click
    Dim ptCurrent As _invapp.ActiveDocument
    Dim mpropProp As Inventor.MassProperties
        mpropProp = ptCurrent.componentdefinition.massproperties
End Sub
_invApp is used on other subs in the class but for some reason I can't get the new button's code to recognize _invApp.
Anyone know what I did wrong?
I think your issue is you are trying to Dim ptCurrent As _invapp.ActiveDocument, where .ActiveDocument get/sets the active inventor document and isn't an object type. I think you are looking for.
Dim ptCurrent As Document = _invapp.ActiveDocument
JBEDsol
That is a good point, need to fix my code.
However the problem I'm having is before that.  _invApp should be recognized as an application but it's not recognized.  I'm not sure why the public application declared can't be found, it should be seen as a public variable but it's not.
Can you post the error you are getting?
Also do you have something that is connecting the Inventor Application to your object? Because based on the code you posted, you are but defining _invApp as Inventor.Application but aren't assigning the actual application to it. So _invApp is typed as Inventor.Application but doesn't actually contain the application itself so .ActiveDocument won't find anything
Something like this, although I'm not sure how it works for global variables.
Dim _invApp as Inventor.Application = Get_invApp()
Function Get_invApp()
		Dim oinvApp As Inventor.Application
		Try
			oinvApp = Marshal.GetActiveObject("Inventor.Application")
			Return oinvApp
		Catch ex2 As Exception
			MsgBox(ex2.ToString())
			MsgBox("Unable to get or start Inventor")
			Return Nothing
		End Try
	End Function
Based on some searching it could be an issue with how you are defining a global variable. I'm not familiar with it myself but I will post some threads that go into it.
Thread 1
Thread 2
