VB Programming naming standards for inventor
kmiller
kmiller
Hi all,
I am working on trying to learn inventor programming with vb.net.  I know with VB code there are typical naming prefix's, etc... for controls that you can put in your forms.  As I am reading through some programming documents/articles on inventor programming I am noticing in the code examples that there are some possible naming prefixes that are used.  For example oEdge1 for an edge object.  assuming "o" for object.  At this point I do not know if this is the intension of the person who wrote the documents or if I am even "analyzing" it correctly.
My question mainly is, is there a list of some sort of standards or typical naming prefixes that are used when programming for inventor?  If so, what are they or is there somewhere to find them?
If this response answers your question please click "Accept as Solution".
ekinsb
There aren't any naming standards.  Hungarian naming style has been popular and is still often used.  This is when variables have a prefix that indicates the type.  The "o" prefix you see in many of the samples was meant to indicate an object.  Probably a better prefix would have been to use "inv" for an Inventor object.  (I can criticize it since I'm the one that started the "o" prefix in the samples 🙂 )  Microsoft is suggesting not to use hungarian notation for variable anymore since Intellisense provides information for the variable by just hovering the cursor over the name.
A great post about the current Microsoft naming recommendations can be found here: http://10rem.net/articles/net-naming-conventions-and-programming-standards---best-practices
Brian Ekins
Mod the Machine blog
