VB.NET - Check if Inventor is open question
In the code below, I want to check if Inventor is open, if so I will discern
if the part is a part, or referenced from an assembly. Finally, I will do a
save-as to a new filename.
Right now, oApp is nothing, wvwn when I have Inventor open. I believe this
is the problem. In .NET, I cannot use things like ThisApplication or
ThisDocument.
I do have references to Inventor and InventorApprentice in my solution
explorer for VB.NET. Because I am planning on running this code while in an
editable drawing, I believe the Inventor reference is the ont that applies.
Thanks in advance for any answers that can be provided.
Steve Anderson
' Check if Inventor is open, if so define file type in use.
Dim oApp As Inventor.Application
Dim oDoc As Inventor.Document = oApp.ActiveEditObject
oApp.ActiveDocument.Activate()
If oApp.ActiveDocumentType.kPartDocumentObject = True Then
Dim oPart As Inventor.Document = oApp.ActiveDocument
ElseIf oApp.ActiveDocumentType.kAssemblyDocumentObject = True Then
Dim oPart As Inventor.Document = oApp.ActiveEditObject
So far, I've come up with this:
Dim oApp As Inventor.Application = GetObject(, "Inventor.Application")
oPart = oDoc.ActiveDocument
oPart = oDoc.ActiveEditObject
oPart.SaveAs(PartToSave, False)
"Steve Anderson" wrote in message
news:5013098@discussion.autodesk.com...
ThisDocument.
Steve Anderson
I was able to answer my own last question. It seems now the part is not
being defined (oPart). I wonder how this works if I have multiple sessions
runnng. Is there a way to count the sessions? If one session is running,
the program could run - otherwise it would need to be halted. And, how do I
define the oPart variable?
Thanks in advance
Steve Anderson
ThisDocument.
Steve Anderson
Steve,
Read your VBA tutorials, you MUST remember to Set any object otherwise you have an error. So your code would look like
Public Sub FooBar()
' get the app
Set oApp = GetObject(, "Inventor.Application")
If oApp is Nothing Then Exit Sub
' you can also get the app like this (from inside a IV macro)
' Set oApp = ThisApplication
Dim oPart As Inventor.PartDocument
Dim oAsm As Inventor.AssemblyDocument
Set oPart = oDoc.ActiveDocument
Set oAsm = oDoc.ActiveDocument
End Sub
