Vb.Net - Change the color of a part (ipt) using RGB values
isocam
isocam
Can anybody help?
I have the following VBA macro that changes the color of a part (ipt) using RGB values.
Function ChangeColour()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oAppearence As Asset
Set oAppearence = oDoc.Assets.Add(kAssetTypeAppearance, "Generic")
Dim oColor As ColorAssetValue
Set oColor = oAppearence.Item("generic_diffuse")
Red = 0
Green = 145
Blue = 255
oColor.Value = ThisApplication.TransientObjects.CreateColor(Red, Green, Blue)
Dim oExtFeats As ExtrudeFeatures
Set oExtFeats = oDoc.ComponentDefinition.Features.ExtrudeFeatures
If oExtFeats.Count = 0 Then Return
Dim oExtrude1 As ExtrudeFeature
Set oExtrude1 = oExtFeats.Item(1)
oExtrude1.Appearance = oAppearence
End Function
Can anybody change the macro so that it can work using a "Stand Alone" Vb.Net program?
Many thanks in advance!
Darren
WCrihfield
Hi @isocam.  Maybe like the following version.  Will likely need to either 'pass' the Inventor Application to it, or have the Inventor Application as a shared variable at a higher level, because the 'ThisApplication' term is not recognized in other settings, unless you 'define' it.
Sub Main
	ChangeColour(ThisApplication)
End Sub
Sub ChangeColour(oInvApp As Inventor.Application)
	Dim oDoc As PartDocument = oInvApp.ActiveDocument
	Dim oAppearence As Inventor.Asset = oDoc.Assets.Add(AssetTypeEnum.kAssetTypeAppearance, "Generic")
	Dim oColor As ColorAssetValue = oAppearence.Item("generic_diffuse")
	Dim Red As Byte = 0
	Dim Green As Byte = 145
	Dim Blue As Byte = 255
	oColor.Value = oInvApp.TransientObjects.CreateColor(Red, Green, Blue)
	Dim oExtFeats As ExtrudeFeatures = oDoc.ComponentDefinition.Features.ExtrudeFeatures
	Dim oExtrude1 As ExtrudeFeature = oExtFeats.Item(1)
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
