VB.net cant call Sub in event (Inventor API)
j.romo
j.romo
Hello, I have been trying to call a Sub on a Button Event and no luck
Public Class frmFLOR
    Sub Main()
        Dim invApp As Inventor.Application = GetObject(, "Inventor.Application")
        AddSketch(invApp)
    End Sub
    Private Sub btnSketch1_Click(sender As Object, e As EventArgs) Handles btnSketch1.Click
' here is how I call the sub, But it doesnt Work
        AddSketch()
    End Sub
    Public Sub AddSketch(ThisApplication As Inventor.Application)
        Dim oCompDef As PartComponentDefinition
        oCompDef = ThisApplication.ActiveDocument.ComponentDefinition
        Dim oSketch As PlanarSketch
        oSketch = oCompDef.Sketches.Add("XY Plane", True)
        oSketch.Name = "Master Sketch"
    End Sub
End Class
Any help would be apreciated
WCrihfield
Hi @j.romo.  It looks to me like you may just be missing a line to declare the 'btnSketch1' variable as having Events you want to be able to access.  A like something like the following, I believe:
Private WithEvents btnSketch1 As ????
...I assume that 'btnSketch1' represents a System.Windows.Forms.Button, but I was not 100% sure.
Wesley Crihfield
(Not an Autodesk Employee)
j.romo
Yes the  'btnSketch1' is a button of a Form in Visual Studio, right now I can Open the form but cant call the Sub  AddSketch().
I want to ru the Sub once I click on the Button
j.romo
I get this error in the debug
You didnt Specify an argument for the parameter 'ThisApplication' of 'Public Sub AddSketch(ThisApplication As Application)
j.romo
Ok I found the problem,
it seems that to call a function we need to add (g_inventorApplication)
code looks like this:
    Sub Main()
        AddSketch(invApp)
    End Sub
        AddSketch(g_inventorApplication)
    End Sub
        Dim xyPlane As Inventor.WorkPlane = oCompDef.WorkPlanes.Item(3)
        oSketch = oCompDef.Sketches.Add(xyPlane, False)
    End Sub
