VB.net After print event
pball
Mentor Mentor
pball
I have part of my addin adding info to a drawing when it's printed or exported using the user event on activate command. It works quite well and now I would just like a method to remove that info after it is printed or exported.
I've looked at the user events for on start and stop command but I can't make heads or tails if that's what I really need. The only parameter those events include is the CommandID as CommandIDEnum and I can't find any info on those ID numbers.
What is a good way to run something after printing? I know there is an addin that does something similar so I'm sure there is a way. Thanks
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
pball
Well who'd of though on terminate command would be the compliment of on activate command. Joking aside that event is triggered when a command finishes or is canceled. So that lets me add my info and remove it after it's printed or exported and it also removes it if you cancel doing printing/exporting also.
Chalk up another self answered question lol
