VB error in code
VB error in code
KenVaessen
VB error in code
KenVaessen
I've got the next error in VB
\Forms\03_Tools\Frm2dPublish.vb(48,5): warning BC42105: Function 'AssemblyResolve' doesn't return a value on all code paths. A null reference exception could occur at run time when the result is used.
1>vbc : warning BC40059: A reference was created to embedded interop assembly 'Autodesk.Inventor.Interop, Version=26.0.0.0, Culture=neutral, PublicKeyToken=d*************' because of an indirect reference to that assembly from assembly 'MCTY, Version=1.0.0.1, Culture=neutral, PublicKeyToken=null'. Consider changing the 'Embed Interop Types' property on either assembly.
It refers to the next code Frm2dPublish
#Region "START PROGRAM"
    Private Function AssemblyResolve(ByVal sender As Object, ByVal e As ResolveEventArgs) As Assembly
        Dim result As System.Reflection.Assembly = Nothing
        If e.Name.ToLower().Contains("grid") = True Then
            result = System.Reflection.Assembly.Load(e.Name)
            Return result
    End Function
    Public Sub New()
        AddHandler AppDomain.CurrentDomain.AssemblyResolve, AddressOf AssemblyResolve
        ' This call is required by the designer.
        InitializeComponent()
        _InventorApplication = StandardAddInServer.InventorApplication
        _InventorApplication.SilentOperation = True
    End Sub
Ralf_Krieg
Hello
Can you try it this way?
    Return result
End Function
or alternativ
        AssemblyResolve = System.Reflection.Assembly.Load(e.Name)
End Function
R. Krieg
RKW Solutions
www.rkw-solutions.com
KenVaessen
I've deleted the first part so the problem is solved. I've got another error. Can anybody help me with this one?
1>------ Rebuild All started: Project: M*****_AddIn, Configuration: Debug Any CPU ------
1>vbc : warning BC40059: A reference was created to embedded interop assembly 'Autodesk.Inventor.Interop, Version=26.0.0.0, Culture=neutral, PublicKeyToken=d*********' because of an indirect reference to that assembly from assembly 'M****, Version=1.0.0.1, Culture=neutral, PublicKeyToken=null'. Consider changing the 'Embed Interop Types' property on either assembly.
1> M*******_AddIn -> F:\*********.dll
1> Microsoft (R) Manifest Tool
1>
1> Copyright (c) Microsoft Corporation.
1>
1> All rights reserved.
1>
========== Rebuild All: 1 succeeded, 0 failed, 0 skipped ==========
Ralf_Krieg
Hello
Visual Studio has created a reference to the Autodesk.Inventor.Interop.dll in your current project. That's because the assembly "MCTY" you also have a reference to in your current project, has a reference to this Autodesk.Inventor.Interop.dll.
Go to your project properties, select the tab references and double click the Autodeks.Interop.dll. Now you should see the reference properties. Set "Embed Interop types" to true and compile again.
R. Krieg
RKW Solutions
KenVaessen
The interop was filled in false. Adjust this and works ok!
