VB Driven motion
VB Driven motion
Message 1 of 12
VB Driven motion
Hi, I shall describe a simplified version of what I am trying to acheive for ease of communication:
Create an Inventor assembly comprising a floor plane and 2 cubes. Position the 2 cubes to the side initially.
Create a VB.net GUI which allows a user to select a cube from a pop-down list, enter a Time value (say in seconds) and a location on the floor (x and y) and click an Enter button.
The values are sent to Inventor and at this point in time the cube moves to the x, y location (does Inventor have any understanding of time?)
By repeating the process the cubes will move to different locations over time.
Each Task (comprising a cube name, time and location) may need to be stored in a database or array.
I am being asked to develop a planning tool which enables assemblies to be moved about a limited floor area without collisions and the movements stored for review and analysis.
We need a simple GUI with a timeline and a 3D view of the Inventor scene to review and communicate the strategy.
Thank you for reading this.
Replies (11)
Message 2 of 12
Use "Animator" and be done! 😉
http://www.sdotson.com/animator.asp
Cheers,
T. Ham
CAD Automation & Systems Administrator
CDS Engineering BV
HP xw4300 Workstation
Dual Pentium XEON 3.6 Ghz
4 GB SDRAM
NVIDIA QUADRO FX 3450/4000 SDI (Driver = 8.4.2.6)
250 GB SEAGATE SATA Hard Disc
3Com Gigabit NIC
Windows XP Professional SP2
Autodesk Inventor Series 10 SP3a
Message 3 of 12
Thanks for the suggestion.
Does Animator assist in the development of an Inventor sequence which I can then access the values of through my VB interface?
Message 4 of 12
To be honest, I have no clue 🙂
Allthough I don't use a lot of Add-ins (I create them myself), I do know
where to find them. Kent Keller, Charles Bliss and Sean Dotson have a huge
amount of Add-ins (or code snippets) on there websites. I usualy redirect
people to the right place 🙂 They are all good guys, and contacting them
directly should be no problem.
Also, Inventor Studio should be capable of doing what you want, but I am
quite sure that limited things (or even nothing) from Inventor Studio have
been exposed in the API.
HTH,
T. Ham
CDS Engineering BV
4 GB SDRAM
3Com Gigabit NIC
Message 5 of 12
Thank you for your advice.
I am looking at Animator as we speak (type!). A simple keyframe animation in Studio driven from my VB GUI would have been ideal.
I guess I am trying to acheive, in a simple way, what Animator is doing so it can be done.
I will contact the experts you mentioned for advise. If anyone has any advise please do not assume I have solved it yet, I welcome your thoughts.
Regards
Message 6 of 12
Now that I think of it...
iDrive (written by MattH) is another program which can drive constraints...
See http://www.mcadforums.com/forums/viewtopic.php?t=3295
Anyway, what you want to do is possible 🙂
T. Ham
CDS Engineering BV
4 GB SDRAM
3Com Gigabit NIC
Message 7 of 12
You're on the ball Teun,
Driving Constraints through VB seems straight forward, in fact I shall be using Design Intent to handle engineering rules on the project between the VB GUI and Inventor. My concern is with time. How do I invoke a part/assembly to move at a point in time defined through my VB GUI and remain in place until the next point in time when the part/assembly is asked to move?
Message 8 of 12
You should be able to use the VB Timer object or Control. But it also
takes a little time for Inventor to make the move and update the view
depending on the size of the assembly etc.
I also have a program KWiKDrive on my site that drives constraints.
___________________
Kent Keller
www.kwikmcad.com
wrote in message news:5516743@discussion.autodesk.com...
to move?
Message 9 of 12
Thank you Kent for your advice.
Would you be willing to read a short but more specific description of my (challenging) project. I would be interested in your instinctive reaction as to which direction I should take to develop a solution.
Regards
Message 10 of 12
Chris,
I would be intrested in seeing what you want to do to. Depending on your
specific requirements there may be two very different approaches.
Brian Ekins
Autodesk Inventor API
wrote in message news:5516790@discussion.autodesk.com...
Regards
Message 11 of 12
Brian, how do I contact you? Message was edited by: Chris Molland
Message 12 of 12
This will work: brian.ekins@autodesk.com
Brian Ekins
wrote in message news:5516798@discussion.autodesk.com...
