Vault Category
Vault Category
f_calebh
Vault Category
f_calebh
Is it possible to get the Vault Category Name for a file? I'm writing a code that I want to set up with an event trigger, but I only want the code to run for files of a specific Vault Category.
I've found how to get the Lifecycle State online, but I can't figure out how to access the Vault File Category.
https://adndevblog.typepad.com/manufacturing/2019/04/connecting-vault-and-accessing-vault-file-statu...
g.georgiades
@f_calebhIt is basically the same thing as listed in the link you provided.
Simply replace
Dim lifeCycleInfo As VDF.Vault.Currency.Entities.FileLifecycleInfo = mFileIt.LifecycleInfo
Messagebox.Show(lifeCycleInfo.Statename)
With
Dim categoryInfo As VDF.Vault.Currency.Entities.EntityCategory = mFileIt.Category
Messagebox.Show(categoryInfo.Name)
You can find the few readily available properties in the FileIteration Documentation found from extracting the chm help document from "C:\Program Files\Autodesk\Vault Client 2025\SDK\Setup.exe"
Accessing system or user properties that are not directly part of the FileIteration object requires a bit more effort.
f_calebh
That's what I assumed, but I get an error:
Dim mVltCon As VDF.Vault.Currency.Connections.Connection
mVltCon = VB.ConnectionManager.Instance.Connection
If  mVltCon Is Nothing Then
     MessageBox.Show("Not Logged In to Vault! - Login first and repeat executing this rule.")
     Exit Sub
Dim VaultPath As String = ThisDoc.PathAndFileName(True)
VaultPath = VaultPath.Replace("C:\MyPath", "$")
'flip the slashes
VaultPath = VaultPath.Replace("\", "/")
Dim VaultPaths() As String = New String() {VaultPath}
Dim wsFiels() As AWS.File = mVltCon.WebServiceManager.DocumentService.FindLatestFilesByPaths(VaultPaths)
Dim mFileIt As VDF.Vault.Currency.Entities.FileIteration = New VDF.Vault.Currency.Entities.FileIteration(conn, wsFiels(0))
Dim FileProp As VDF.Vault.Currency.Properties.ContentSourcePropertyDefinition
Dim CategoryInfo As VDF.Vault.Currency.Entities.EntityCategory = mFileIt.Category
MessageBox.Show(CategoryInfo.Name, "Title")
g.georgiades
You have an error on this line - your connection variable is mVltCon, not conn.
It looks the original source also has the same error.
f_calebh
That was it! I had the same variable error when grabbing Lifecycle state, so I'm not sure why that worked, but this was what I needed. Thanks!
g.georgiades
The FileIteration object only needs the vault connection for a couple properties.... For the lifecycle state - it can pull directly from the WebServices File. When it grabs the category information - it has to ask the provided connection for it. If the connection is null, then it will not be able to query for the category. It seems you had bad luck in that the property you needed was one of the only ones that needed the connection...
Here is a debug dump from visual studio - the left side has null passed for the FileIteration connection. The only properties that it could not pull from the WebServices file are the Category and the EntityClass.... at least for a standard vault file.
