Variable update bug
Variable update bug
S7RM7RPR
Variable update bug
S7RM7RPR
First, I apologise if I'm not clear so if you need clarification just ask and I'll probably reply pretty quick. (assuming it isn't 3 years later)
I have a program set up where I am importing some 400 unique values from a database file via a .dll (probably irrelevant) based on specific design criteria. What I need, is to "null" (0, blank, or false respectively) all the parameters in Inventor (Mechanical 2015) whenever I import a new design so that I don't accidentally carry over incorrect data.
1. Ideally when I import, if the value is 'nothing' it should set the parameter to null but it appears that it just skips the parameter when it is 'nothing'. When I set the parameters as "parameter("example")" it sees 'nothing' as Boolean and won't update the parameter. I've considered creating a temporary array to convert 'nothing' values, but then I don't know if the value is supposed to be an integer, Boolean or text.
2. When I run the "reset" code and the "import" code separately (as two different buttons), it works cleanly every time. When I run them sequentially, either combined into one rule or as two separate rules, it will reset all values but then it won't update the new imported values - and the values seem to update differently for different designs. For one design it would import every value except for 3 specific values, and then for a different design it would only update 1 value. Then, when you run the logic twice in a row, it will flip-flop between the updated values and null values. I've even added a delay between running import and reset, but it will only work if you run the rules totally separately.
At this point my conclusion is that it just seems to be a bug in the way Inventor updates it's values and I have to leave it as two separate functions
S7RM7RPR
Some example code. I've left out a couple things for reasons so assume that the import function works as is (aside from the whole 'nothing' issue)
SyntaxEditor Code Snippet
Sub Main()
    IMPORTED = False
    ResetValues()
    InventorVb.DocumentUpdate()
    System.Threading.Thread.Sleep(10000)
    ImportValues()
    MessageBox.Show("New design imported.", "Fini.",MessageBoxButtons.OK)
    IMPORTED = True
End Sub
Sub ResetValues()
    Parameter("ABC1") = ""
    Parameter("EFG2") = 0
    Parameter("RTU3") = False
End Sub
Sub ImportValues()
    'OUTPUT VARIABLE SETUP IS REMOVED BUT FUNCTIONS CORRECTLY
    output = '.DLL CONNECTION'
    ABC1 = output(1)
    EFG2 = output(2)
    RTU3 = output(3)
End Sub
bshbsh
In your stripped down ImportValues code, did you define ABC1, EFG2, RTU3 as Parameter("ABC1"), Parameter("EFG2") and Parameter("RTU3")?
S7RM7RPR
The ABC EFG and RTU variables are the straight Inventor parameters
