Using Vault Addin to check in/out files
Hi
is it possible to use the Inventor Vault AddIn to perform simple actions?
I would like to automate Inventor to checkout file(s) from vault, perform some actions on the files (setting properties, ...), save the changes and then check-in the file(s) again.
And everything should be as simple as possible, so I would like to avoid "learning" the web-services Vault API.
Thanks in advance
neutro
There's another newsgroup for Vault that would be better for this question,
but as far as I'm aware there is not an API for the Vault Add-In (the client
side of Vault), only for the Vault server.
Brian Ekins
Autodesk Inventor API
