Using the SketchEntitiesEnumerator object in VB
I am writing an Add-In for inventor and one of the things I want to do is querry the open sketch for existing entities. If the number of entities is greater than 0, I want to send a message to the user. I have been trying to use the SketchEntitiesEnumerator.Count and have been unsuccessful. I can get the program to compile but when I test it in inventor it gets an error. What are the proper variable declarations to make this work?
In general I find the inventor help on the API to be somewhat cryptic. Can you recommend a book that deals with the API in depth?
Here's a little sample that does what you asked
about.  The ActiveEditObject property of the Application will return
whatever object is currently being edited.
Public Sub
CheckSketch()
    If TypeOf ThisApplication.ActiveEditObject
Is Sketch Then
        Dim oSketch As
Sketch
        Set oSketch =
        If oSketch.SketchEntities.Count
> 0
Then
MsgBox "The active sketch contains some
geometry."
Else
MsgBox "The active sketch is
empty."
        End
If
    Else
MsgBox "A sketch is not active."
End
Sub
-Brian
I
depth?
