Using the "Copy Properties" function in a drawing
Hubert_Los
Hubert_Los
How to copy dimension properties to another dimension?
Thank you for all your help
JelteDeJong
There is no easy API call o do the same. But you can copy each property individually from one to the other. something like this:
Dim dimension1 As LinearGeneralDimension = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "")
Dim dimension2 As LinearGeneralDimension = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "")
dimension2.Style = dimension1.Style
dimension2.Layer = dimension1.Layer
dimension2.Text.FormattedText = dimension1.Text.FormattedText
dimension2.Precision = dimension1.Precision
dimension2.IsInspectionDimension = dimension1.IsInspectionDimension
dimension2.FirstArrowheadType = dimension1.FirstArrowheadType
dimension2.SecondArrowheadType = dimension1.SecondArrowheadType
dimension2.ArrowheadsInside = dimension1.ArrowheadsInside
But not all dimension types have the same properties therefore when a user (or code) selects a dimension you need to know what kind of dimension you are dealing with. And act according to that.
Jelte de Jong
Blog: hjalte.nl - github.com
