Using the eval function
pball
Mentor Mentor
Message 1 of 12
pball
Unfortunately it seems the eval function is not availble in inventor's vba. I know other programs with vba can use that function so I'm wondering if it's possible to make it accessable in inventor vba. I tried loading references to some microsoft office libraries because I know excel and other office programs can use eval, but that doesn't work. Anyone have a solution for this, I've already had to use work arounds to not being able to use eval before.
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
Userscript to edit forum links to jump to first unread post
Jump To First Post Userscript
Replies (11)
Message 2 of 12
jdkriek
Add reference to MS Script Control
Public Sub eValTest()
    'Add ref to MS Script Control
    Dim oSC As ScriptControl
    Set oSC = New ScriptControl
    oSC.Language = "VBScript"
    Dim sResult As String
    sResult = oSC.eVal("4*5")
    MsgBox sResult, vbOKOnly, "Result"
End Sub
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Message 3 of 12
pball
Thanks, your example works perfectly. Though what I'm trying to do isn't working so well.
I'm trying to dynamically call a function and I'm getting a type mismatch error on "etest". Would you happen to know why this happening.
Public Sub et()
    Dim fname As String
    fname = "etest()"
    noop = oSC.Eval(fname)
End Sub
Public Function etest()
    Debug.Print "works"
End Function
Message 4 of 12
jdkriek
Here you go:
Public Sub et()
    Dim oSC As New ScriptControl
    fname = oSC.Eval(etest())
End Sub
    Debug.Print "works"
End Function
Jonathan D. Kriek
Message 5 of 12
pball
I'm sorry but doing it that was doesn't help me. I'm looking to call a function which name is in a variable. Basically I'd like a function which can in turn call another function which name was passed to the first function as a variable
Message 6 of 12
jdkriek
I see now, just take the quotes off here:
Public Sub et()
    Dim fname As String
    fname = etest() 'no quotes
End Sub
    Debug.Print "works"
End Function
Jonathan D. Kriek
Message 7 of 12
pball
Wow that was simple. I feel like banging my head on my desk now, it also might wake me up some lol. It should be much easier and simpler to remake this recursive function I have which calls other functions to do stuff.
Message 8 of 12
jdkriek
I agree, it should be easier - thier scope of VBA is limited.
Jonathan D. Kriek
Message 9 of 12
pball
Well I'm sorry to say but I found an issue with this. The eval function works but my end goal isn't working correctly.
Public Sub et()
    Dim fname As String
    Debug.Print "shouldn't run etest yet"
End Sub
    Debug.Print "works"
End Function
 The above code appears to work but it doesn't in the way intended. I want the function to be called stored in a variable and executed later. But this code is executing the function when trying to add it to the variable. When I run this code the function etest runs before the debug.print line which shows the eval line isn't where it's being evaluated.
All the examples I've found set the function to be called as a string in a variable and use that variable in the evaluate function. That results in a type mismatch error when I try that. I'm wondering if things work differently in programs that have a native evaluate function and it just won't work in inventor.
Message 10 of 12
jdkriek
Indeed, for the life of me I don't understand why Inventor VBA just doesn't have a Eval() function built-in.
I mean AutoCAD VBA does.
Jonathan D. Kriek
Message 11 of 12
Wannes.V
What do I need to import to use eval function with ilogic?
Imports Microsoft.VisualBasic.???
what does
mean?
Looking for a easy way to calculate math expression string to numeric value.
Message 12 of 12
WCrihfield
Hi @Wannes.V.  Maybe the following tool will work better for you in an iLogic rule.
UnitsOfMeasure.GetValueFromExpression
The UnitsOfMeasure object can be accessed either directly from the main Inventor Application, of from an Inventor Document object directly.  But keep in mind that the value it gives you will always be in 'database units', which may be different from your default document units.  For example, centimeters is the database unit for length or distance, and radians is the database unit for angles, and so on.
Wesley Crihfield
(Not an Autodesk Employee)
