Using Tab groups in Ilogic
toon.sol
toon.sol
I'm using 2 Tab groups in my form. Above them I have a "type" selector.  If it possible to use the type selection to set one of the Tab groups active?
type = Red then Tab 1 is active
type = Green then Tab 2 is active
Or the other way around, by choosing one of the tab that triggers the right type selection.
Set Tab 1 as active then type becomes Red
Set Tab 2 as active then type becomes Green
Hope it makes sense to you guys. All help is welcome.
Toon
FINET_Laurent
Hi @toon.sol ,
In the form editor, when clicking on the tab and going in it's properties, you can asign a True/false parameter to enable / disable the said tab :
Above, the said user parameter I created is "EnableTab".
I would maybe link the parameter with your parameter in an iLogic rule :
If Param = "Red" Then EnableTab = False
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
toon.sol
Thanks for your (swift) reply.
I know I can turn on and off the Tab Group by using the Enabling Parameter but that doesn't set the Tab I want as active.
FINET_Laurent
Hi @toon.sol,
I'm not sure you can do this. Here is a previous topic on the subject :
i logic Form change the active tab - Autodesk Community - Inventor
Kind regards,
FINET L.
