Using RxInventor.tlb in Inventor 2019
oransen
oransen
This is not a question but a hint to any of the other 5 or 6 people using the Inventor C++ COM API.
I've found that in order to compile properly inside InventorUtils.H I had to change the line which starts like this...
#import "RxInventor.tlb" no_namespace...
... to start like this...
#import "C:\Program Files\Autodesk\Inventor 2019\Bin\RxInventor.tlb" no_namespace...
...even though I had the correct search path in my VC project settings.
Hell, the next time I'm going to use C# !
YuhanZhang
You're right, it should use full path for the TLB. But if you get the InventorUtils.h from the folder(C:\Users\Public\Documents\Autodesk\Inventor 2019\SDK\DeveloperTools\Include) after installing the DeveloperTools.msi then the full path for the RxInventor.tlb will be set for it already, this is done in the installer, the installer will run a script to do this. If you don't see the full path after installing the installer then seems there is a problem there. Did you run the installer with admin account?
Below is what I see after installing the DeveloperTools:
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
oransen
Hello @YuhanZhang ,
Thanks for replying.
Note that there are two versions of DeveloperTools.msi, one for older compilers, and I used that older one.
After the installation there was no path in the InventorUtils.h, it took me quite some time to find out the problem.
Yes, I always run as admin.
All the best
Owen
