Using Replace with numeric wildcards
b.tuckerB6DT3
b.tuckerB6DT3
I am writing a function that will parse through all my sheets and replace the sheet name from:
Assembly:1
Details:2
to
Sheet 1 - Assembly:1
Sheet 2 - Details:2
I am having troubles using the replace command to ignore the ":1" at the end of the original title to be able to replace it. Can anyone give me some insight on how to use RegEx modifiers to select any number?
Dim oDoc As Document
Dim dwgDoc As DrawingDocument = ThisDoc.Document
i = 1
For Each dwgSheet As Sheet In dwgDoc.Sheets
	vTest = dwgSheet.Name.Replace(":", "")
	vTest = vTest.Replace("#", "")
	If i = 1
		MsgBox(vTest)
	end if
	'dwgSheet.Name = "Sheet " & i & " - " & vTest
	i = i + 1
Next
lmc.engineering
vTest = dwgSheet.Name.split(":")(0)
