Using Random function in iLogic what is the Code
I know you can use an operator in the parameters as "random()" to produce a random number >0 and <1 as a decimal, but what is the code for doing this in Inventor iLogic? Random just isn't an expression when it comes to iLogic it just says it's a type. Any Insight ?
I could use it in my parameter but once it is in a formula then "random" stays one value.
bradeneuropeArthur
With this piece of code:
Sub Main()
    'Initialize the random number generator
    '=> Randomize : add this before you call the Rnd function to obtain completely random values
    Randomize
    'Random whole number between 1 and 50 :
    random_number = Int(50 * Rnd) + 1
    MsgBox (random_number)
End Sub
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
vladimir_michl
See also an example of using random dimensional parameters and appearances to drive "dynamic" parts and assemblies in Inventor:
https://www.cadforum.cz/cadforum_en/random-shape-and-appearance-of-an-inventor-part-or-assembly-tip1...
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
