Using patterns and iLogix
Is it possible to add a part to a pattern or delete on from a pattern based on a rule?
Number of parts = 5
part 1
part 2
part 3
part 4
part 5
are in pattern
Number of parts = 4
part 1
part 2
part 3
part 4
are in pattern part 5 is no longer available in the pattern.
any ideas? i'm not seeing it.. could be simple but via iLogic i van only make part 5 in the first component invisible..
rjay75
To add remove elements in a pattern by name do this.
To remove a named element from a pattern
Dim asmDef = ThisDoc.Document.ComponentDefinition
Dim compPattern As OccurrencePattern
Dim compObj As ComponentOccurrence
compObj = asmDef.Occurrences.ItemByName("ElementName")
compPattern = asmDef.OccurrencePatterns("PatternName")
If Not ((compObj Is Nothing) Or (compPattern Is Nothing)) Then
    Dim newCol As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection()
    For Each obj As Object In compPattern.ParentComponents
        If Not obj Is compObj Then newCol.Add(obj)
    Next
    newCol.Add(compObj)
    compPattern.ParentComponents = newCol
To add a named element back to a pattern
Dim inPattern As Boolean = False For Each obj As Object In compPattern.ParentComponents If obj Is compObj Then
inPattern = True
Exit For
Else
newCol.Add(obj)
End If Next
If Not inPattern Then newCol.Add(compObj) compPattern.ParentComponents = newCol
End If End If
Thank you for the quick reply rjay75, but i have a problem with the code as you supplied..
I inserted it in a rule & tried it out but nothing happens when i run the rule. What is wrong?
I attached a screenshot with my browser & rule.
compObj = asmDef.Occurrences.ItemByName("Rib onder - Centrisch") 'Part name
compPattern = asmDef.OccurrencePatterns("Pattern - Ribben") 'Pattern name
    Next
    newCol.Add(compObj)
rjay75
There's an extra line in there while I was testing the code.
Remove the line
newCol.Add(compObj)
