Using material option in form.
Message 1 of 12
Good day,
I am busy with fine tuning our templates for parts, assemblies and drawings created in Inventor.  One of the things on my list is to simplify (also read "enforce") the correct entry of specific information at part, assembly and drawing level.  So one of the main issues I have is that when one brings in contractors for limited term work, their understanding of our company processes are not quite where it should be to ensure a smooth flowing process from 3D modelling through to producing drawings.
So the idea is to use an event linked iLogic Form to ensure that they are reminded about very specific information / meta data / properties that needs to be entered during this time in the process.  I have been able to get just about everything to work, except to show the material selection in my Form.  It is not shown under the iProperties or parameters options when one creates the Form so I cannot just simply drag the option across.  I Googled the issue but the one possible solution I found also does not do the trick.  Basically I want to replicate the drop down selection to specify the material, but just in the Form environment.  Below is a screen capture of the Form as I have it currently (work in progress), the material listing should be where the Material heading is.
Screen capture of current FormScreen capture of current Form
Anyone that can assist with this please?
Regards
Kobus
Replies (11)
Message 2 of 12
Sergio.D.Suárez
Hi, I'll give you some examples in ilogic that maybe they could serve you.
If you only want to read your active material on your form you could use the following code.
Dim oDoc As PartDocument = ThisDoc.Document
MessageBox.Show(oDoc.ActiveMaterial.DisplayName)
If you want to change material, I think a good approach would be to previously select the library, and then select the material as in the following code
Dim oAL_List As New ArrayList
Dim lib_List As New ArrayList
For Each oAL As AssetLibrary In ThisApplication.AssetLibraries
	If InStr(oAL.DisplayName , "Material") <> 0 Then
		oAL_List.Add(oAL.DisplayName)
Next
Dim oALSelect As String = InputListBox("Select Asset Library", oAL_List, oAL_List(0), "Change Part Material", "Available Selections")
If oALSelect Is Nothing Then Exit Sub
Dim oLib As AssetLibrary =ThisApplication.AssetLibraries(oALSelect)
For Each libAsset In oLib.MaterialAssets
	lib_List.Add(libAsset.DisplayName)
Next
Dim oLibAssetSel As String = InputListBox("Select Material", lib_List, lib_List(0), "Change Part Material", "Available Selections")
If oLibAssetSel Is Nothing Then Exit Sub
oDoc.ActiveMaterial = oLib.MaterialAssets.Item(oLibAssetSel)
iLogicVb.UpdateWhenDone = True
 I hope this helps with your form, regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 3 of 12
Pieter_vBiljon
Hi @Sergio.D.Suárez
Thank you for this code. It did work for me, but I made a small change and predefined the Material library that needs to be selected. But one issue I found was that the material list that is displayed is not sorted whatsoever and materials is all over the place. Any ideas on how to solve it to be sorted alphabetically?
Message 4 of 12
JBerns
@Pieter_vBiljon,
You likely have your answer by now, but for the benefit of others I offer this solution.
Use the Sort method  on the list object after the list of materials has been created.
Next
lib_List.Sort
Hope this is helpful.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Message 5 of 12
Pieter_vBiljon
Thank you @Anonymous.
Message 6 of 12
JBerns
Welcome, @Pieter_vBiljon
CAD Administrator
Message 7 of 12
GosponZ
Rule is working perfect but i can't see my custom Library. It is just this two. Some help please. Thanks
Message 8 of 12
JBerns
@GosponZ,
When in a part or assembly, what libraries are available from the Material menu?
Is your library available in the current project?
Beyond those two factors, I am not sure why your custom library would not be listed.
Perhaps others may have an idea.
Jerry
CAD Administrator
Message 9 of 12
GosponZ
i do see my Library but not when running rule as i placed screen shot. Al material i 'm taking from My Library
Message 10 of 12
WCrihfield
Hi @GosponZ.  In the code that @Sergio.D.Suárez posted, he is filtering library names and only getting ones with "Material" in the name.  You may have to change that line of code to include any that don't contain that exact text in the name.
Wesley Crihfield
(Not an Autodesk Employee)
Message 11 of 12
JBerns
Thanks @WCrihfield , for pointing that out. I overlooked that.
CAD Administrator
Message 12 of 12
GosponZ
Indeed that was so simple. Thank you
