Using Ilogic to Update a Custom Iproperty Depending on a Part's Selected Material
thomass4FBDGA
thomass4FBDGA
I want to update my custom Iproperties to change from yes to no depending on the parts material selected. What script would I use in Ilogic which would read my material selected on a specific part and change multiple "Yes or No" Iproperties within this sketch?
Curtis_Waguespack
Hi @thomass4FBDGA,
Welcome to the forum.
This should get you started.
Hope that helps,
Curtis
Dim oDrawDoc As DrawingDocument = ThisDoc.Document
' Get the first view's model document
Dim oView As DrawingView = oDrawDoc.ActiveSheet.DrawingViews.Item(1)
Dim oModelDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
If Not TypeOf oModelDoc Is PartDocument Then Exit Sub
' For parts
Dim oPart As PartDocument = oModelDoc
' Get the material name
Dim materialName As String = ""
materialName = oPart.ComponentDefinition.Material.Name
' Update the custom iProperty
If materialName = "" Then Exit Sub
iProperties.Value("Custom", "Engineering Paint Standards 1") = (materialName = "Generic")
