Using Ilogic to number part classes in ranges
RainerXGE3N
RainerXGE3N
Hi All,
Please help with my BOM numbering issue. I have various Part classes that we are manually renumbering. I would like Ilogic to renumber them as follows:
Setting: Class 2, Range 2001 - 2999
Outcome:
Assembly BOM Item numbers for this class 2001, 2002, 2003, etc.
RainerXGE3N
Here is my current code that renumbers all same class to 2001, now I need them to ascend.
Dim
oBOM As BOM = ThisAssembly.Document.ComponentDefinition.BOM oBOM.StructuredViewEnabled = True i = 2001 For Each oBOMRow As BOMRow In oBOM.BOMViews.Item("Structured").BOMRows If oBOMRow.ComponentDefinitions(1).Document.PropertySets.Item("Inventor User Defined Properties").Item("Store Type").Value = "STORE PART" Then oBOMRow.ItemNumber = 2001 End If Next
Curtis_Waguespack
Hi @RainerXGE3N , maybe something like this example.
Hope that helps, Curtis
Dim oBOM As BOM = ThisAssembly.Document.ComponentDefinition.BOM
Dim oStoreType As Inventor.Property
oBOM.BOMViews("Structured").Sort("Store Type", True)
oBOM.BOMViews("Structured").Renumber(1001, 1)
iSTOREPART = 2000
iSOMETHINGELSE = 3000
	Dim oDoc As Document = oBOMRow.ComponentDefinitions(1).Document
	Try
		oStoreType = oDoc.PropertySets.Item("Inventor User Defined Properties").Item("Store Type")
	Catch
		Logger.Info("Property not found")
		Continue For
	End Try
	If oStoreType.Value = "STORE PART" Then
		iSTOREPART = iSTOREPART + 1
		oBOMRow.ItemNumber = iSTOREPART
	If oStoreType.Value = "SOMETHINGELSE" Then
		iSOMETHINGELSE = iSOMETHINGELSE + 1
		oBOMRow.ItemNumber = iSOMETHINGELSE
Next
oBOM.BOMViews("Structured").Sort("Item", True)
Results:
RainerXGE3N
Thank you Curtis,
With a few tweaks to cover all 7 classes this work perfectly.
RainerXGE3N
Just an important addition:
Add a line to sort BOM to part number before renumbering then all classes will be sorted in class and Part numbers:
oBOM.BOMViews("Structured").Renumber(9001, 1)
iMANPART = 0
iSTOREPART = 2000
iFAST = 4000
iMAT = 5000
iMANASS = 6000
iJIG = 7000
iREF = 8000
oBOM.BOMViews("Structured").Sort("Part Number", True)
	Try
	Catch
		Continue For
	End Try
	If oStoreType.Value = "MANUFACTURED PART" Then
		iMANPART = iMANPART + 1
		oBOMRow.ItemNumber = iMANPART
	If oStoreType.Value = "JIG" Then
		iJIG = iJIG + 1
		oBOMRow.ItemNumber = iJIG
	If oStoreType.Value = "REF PART" Then
		iREF = iREF + 1
		oBOMRow.ItemNumber = iREF
Dim oBDoc As Document = oBOMRow.ComponentDefinitions(1).Document
	Try
		oPartType = oBDoc.PropertySets.Item("Inventor User Defined Properties").Item("Part Type")
	Catch
		Continue For
	End Try
	If oPartType.Value = "FASTENER" Then
		iFAST = iFAST + 1
		oBOMRow.ItemNumber = iFAST
	If oPartType.Value = "ASSEMBLY" Then
		iMANASS = iMANASS + 1
		oBOMRow.ItemNumber = iMANASS
	If oStoreType.Value = "MATERIAL" Then
		iMAT = iMAT + 1
		oBOMRow.ItemNumber = iMAT
Next
RainerXGE3N
Hi Curtis,
I have some virtual parts that is being skipped and renumbered to the 9000 range. How do I also renumber virtual parts?
RainerXGE3N
I solved the problem.
