Using iLogic to Export faces
m_griffin2WHPP
Message 1 of 10
m_griffin2WHPP
I am trying to build some files that are slightly more automated using iLogic and VBA, and I would like for someone to tell me what I am doing wrong.
Why doesn't it work when you want to generate a .DXF file, its almost like the software is incapable of handling this request. So I am uncertain why an Autodesk Product cannot do this simple operation.
Here is my sample code that is not working.
If someone could run this code, and tell me about the class part of it. I am also running Attribute helper and if there is something I should do in VBA or iLogic. Please reach out to me, I would love to see this Automated.
I would like to use entities instead of attributes.
Thank you
' iLogic code to export all faces as DXF files in the first surface body
' Set the export folder path (modify this to your preferred location)
Dim exportFolder As String = "K:\Michael Griffin\My Drive\EXPORT\"
' Check if export folder exists
If Not System.IO.Directory.Exists(exportFolder) Then
    MessageBox.Show("Export folder does not exist: " & exportFolder, "Folder Error")
    Return
' Get the active part document
Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument
Dim oCompDef As ComponentDefinition = oPartDoc.ComponentDefinition
' Counter for naming files uniquely
Dim faceCounter As Integer = 1
' Loop through all faces in the first surface body
For Each oFace As Face In oCompDef.SurfaceBodies(1).Faces
    ' Construct a file path for the DXF file, naming it with the counter to keep it unique
    Dim dxfFilePath As String = System.IO.Path.Combine(exportFolder, "Face_" & faceCounter & ".dxf")
    faceCounter += 1 ' Increment counter for each face
    ' Debug message to show where the file should be saved
    MessageBox.Show("Attempting to export DXF to: " & dxfFilePath, "Export Path")
    ' Export the face as a DXF file
    Try
        ' Create the transient geometry for the face
        Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
        Dim oPlane As Plane = oTG.CreatePlaneByThreePoints(oFace.PointOnFace, oFace.Vertices(1).Point, oFace.Vertices(2).Point)
        ' Save the face as a DXF file
        oPartDoc.SaveAsDXF(dxfFilePath, oFace, oPlane)
        MessageBox.Show("DXF file exported: " & dxfFilePath, "Export Successful")
    Catch ex As Exception
        MessageBox.Show("Failed to export face: " & faceCounter & vbCrLf & ex.Message, "Export Error")
    End Try
Next
Replies (9)
Message 2 of 10
jnowel
There is no SaveAsDXF Property or Method under the PartDocument Object.
I think you're looking for the ControlDefinition "GeomToDXFCommand" to "Export Face as" command
here's a relevant link that exports faces to DXF based on named entities
Solved: Export Face As DXF - Autodesk Community - Inventor
Message 3 of 10
m_griffin2WHPP
Do you have any sample code of this instance that I can modify?
Message 4 of 10
jnowel
Try edited code based on yours.
Just enable the Messageboxes if you need them
Sub Main
	'Dim exportFolder As String = "K:\Michael Griffin\My Drive\EXPORT\"
	Dim exportFolder As String = ThisDoc.Path & "\test\"
	    Return
	    'MessageBox.Show("Attempting to export DXF to: " & dxfFilePath, "Export Path")
	    Try
	        'Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	        'Dim oPlane As Plane = oTG.CreatePlaneByThreePoints(oFace.PointOnFace, oFace.Vertices(1).Point, oFace.Vertices(2).Point)
	        'oPartDoc.SaveAsDXF(dxfFilePath, oFace, oPlane)
			Call ExportDXF(dxfFilePath, oFace)
	        'MessageBox.Show("DXF file exported: " & dxfFilePath, "Export Successful")
	        'MessageBox.Show("Failed to export face: " & faceCounter & vbCrLf & ex.Message, "Export Error")
	    End Try
	Next
	ThisDoc.Launch(exportFolder)
End Sub
Sub ExportDXF(dxfFilePath As String, oFace As Face)
	ThisDoc.Document.SelectSet.Select(oFace)
	Dim oCmdMgr As CommandManager = ThisApplication.CommandManager
	Dim oCtrlDef As ControlDefinition = oCmdMgr.ControlDefinitions.Item("GeomToDXFCommand")
	oCmdMgr.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent,  dxfFilePath)
	oCtrlDef.Execute
	ThisDoc.Document.SelectSet.Clear()
End Sub
Message 5 of 10
m_griffin2WHPP
Okay you have to try this, I actually got it to work based on that snippet you provided.
Here is what you have to do, run this code by selecting the face that you want to set to be exported and giving it a named attribute.
'ATTRIBUTE FACES
' Ensure there is an object in the SelectSet
If ThisApplication.ActiveDocument.SelectSet.Count > 0 Then
    ' Get the first item in the SelectSet
    Dim oFace As Face
    oFace = ThisApplication.ActiveDocument.SelectSet(1)
    ' Check if the object is a Face
    If TypeOf oFace Is Face Then
        ' Check if the "ExportName" attribute set already exists
        Dim oAttrSet As AttributeSet
        If oFace.AttributeSets.NameIsUsed("ExportName") Then
            ' Use the existing attribute set
            oAttrSet = oFace.AttributeSets.Item("ExportName")
        Else
            ' Create a new attribute set
            oAttrSet = oFace.AttributeSets.Add("ExportName")
        ' Check if the "Name" attribute exists, otherwise add it
        If oAttrSet.NameIsUsed("Name") Then
            oAttrSet.Item("Name").Value = "MyFaceName"
        Else
            ' Add the "Name" attribute with the string type specified
            oAttrSet.Add("Name", ValueTypeEnum.kStringType, "MyFaceName")
        MessageBox.Show("Attribute 'Name' set to 'MyFaceName' for the selected face.", "Success")
    Else
        MessageBox.Show("The selected item is not a face.", "Error")
Else
    MessageBox.Show("No face selected. Please select a face and try again.", "Error")
Then run this rule and it will cycle through all those set faces with attributes and export the faces.
' Define the export folder path
exportFolder = "K:\Michael Griffin\My Drive\EXPORT\"
' Get the active document as a PartDocument
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
' Ensure the document is a part document
If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
    ' Iterate through each face in the surface bodies
    Dim oFace As Face
    For Each oFace In oDoc.ComponentDefinition.SurfaceBodies(1).Faces
        ' Check if the face has an attribute set named "ExportName"
            ' Get the attribute value, which will be used as the filename
            Dim exportName As String
            exportName = oFace.AttributeSets.Item("ExportName").Item("Name").Value
            ' Prepare the file path for the DXF export
            dxfFilePath = exportFolder & exportName & ".dxf"
            ' Set up the GeomToDXFCommand for exporting the face
            Dim exportCommand As ControlDefinition
            exportCommand = ThisApplication.CommandManager.ControlDefinitions("GeomToDXFCommand")
            ' Select the face and activate the export command
            oDoc.SelectSet.Clear()
            oDoc.SelectSet.Select(oFace)
            ' Execute the export command for the selected face
            exportCommand.Execute
            ' Save the document as DXF to the specified file path
            oDoc.SaveAs(dxfFilePath, True)
            MessageBox.Show("Exported face '" & exportName & "' to DXF at " & dxfFilePath, "Success")
    Next
Else
    ' Display an error if the document is not a part document
    MessageBox.Show("This rule only works with part documents (.ipt files).", "Error")
I actually got it to work, but not in the way that I thought it was going to bulk work, you still need to name them individually, but from a manufacturing standpoint this is probably the best method in doing that. My experience using Automation is that there is no one click solves all button. It is all about the small victories.
Thanks for you help!
Try my code!
Message 6 of 10
m_griffin2WHPP
    Dim oFace As Face
    Next
Else
Message 7 of 10
jnowel
just wondering, why still use the "SaveAs" Method?
Message 8 of 10
m_griffin2WHPP
When filling job orders we are taking the same model and making changes to it and will need the faces to write G code for various machines in the shop. The operators need these naming schemes to carry out checks and balances when I make mistake.
THANKS!!!!!!!!
Message 9 of 10
marcin_otręba
Hi, you can give name using  PostPrivateEvent
Call ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, yourname & ".dxf")
yourname should be full file name containing full path
for example:
Call ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, path & oDoc.PropertySets(3)("Part Number").value & ".dxf")
before
EDIT:
remember to use ThisApplication.CommandManager.ClearPrivateEvents before calling PostPrivateEvent.
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 10 of 10
william
@m_griffin2WHPP
Here is another approach that might work for you.
We use this for unwrapped surfaces, a couple of advantages with this method.
- You can unwrap the same surface multiple times and name the unwrapped surface bodies differently. This gets around the limitation of only one named entity for a face.
- You can then orient the surface body with respect to the UCS (if this is a requirement for you), flip, mirror, rotate. The exported surface will take its orientation from the UCS.
Take a look at the below, you would need to add your logic for processing multiple surfaces and parts, but it should be pretty easy.
Sub Main()
Dim oDoc As Document = ThisDoc.Document
ThisApplication.StatusBarText = "Select a Unfolded Surface to Export as DXF"
Dim entity = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select a Unfolded Surface to Export as DXF")
oDoc.SelectSet.Select(entity)
Dim oFace As Face
oFace = oDoc.SelectSet(1)
If Not oFace.SurfaceType = SurfaceTypeEnum.kPlaneSurface Then
	MessageBox.Show("A planar face must be selected, the rule will exit", "Error Handling")
	Return
strDxfTextLine1 = "Text Line 1"
strDxfTextLine2 = "Text Line 2"
strDxfTextLine3 = "Text Line 3"
strDxfTextLine4 = "Text Line 4"
strDxfTextLine5 = "Text Line 5"
DXF_FileName = ThisDoc.PathAndFileName(False) & ".dxf"
Call Process_oSB_DXF(oFace, oDoc, DXF_FileName, strDxfTextLine1, strDxfTextLine2, strDxfTextLine3, strDxfTextLine4, strDxfTextLine5)
End Sub
Sub Process_oSB_DXF(oFace As Face, oDoc As PartDocument, DXF_FileName As String, strDxfTextLine1 As String, strDxfTextLine2 As String, strDxfTextLine3 As String, strDxfTextLine4 As String, strDxfTextLine5 As String)
	Dim oSelectSet As SelectSet = oDoc.SelectSet
	oSelectSet.Select(oFace)
	Dim DXF_FullFileName As String = DXF_FileName
	'MessageBox.Show(DXF_FullFileName)
	Dim File As New System.IO.StreamWriter(DXF_FullFileName)
	SharedVariable("DXF_Data_Exists") = False
	SharedVariable("PosX") = 0
	SharedVariable("PosY") = 0
	DXFHeader(File)
	ExportFace(oFace, File)
	'MessageBox.Show("PosX = " & SharedVariable("PosX") & "PosY = " & SharedVariable("PosY"))
	oSelectSet.Clear()
	Call DXFAddText(File, strDxfTextLine1, SharedVariable("PosX"), SharedVariable("PosY"))
	Call DXFAddText(File, strDxfTextLine2, SharedVariable("PosX"), SharedVariable("PosY") - 5)
	Call DXFAddText(File, strDxfTextLine3, SharedVariable("PosX"), SharedVariable("PosY") -10)
	Call DXFAddText(File, strDxfTextLine4, SharedVariable("PosX"), SharedVariable("PosY") -15)
	Call DXFAddText(File, strDxfTextLine5, SharedVariable("PosX"), SharedVariable("PosY") -20)
	DXFFooter(File,DXF_FullFileName)
End Sub
Sub CalculatePosX_PosY(oPointCol As List(Of Double()), oFace As Face)
Dim oPoint As Point
Dim Array_X As New ArrayList
Dim Array_Y As New ArrayList
For i = 0 To oPointCol.Count - 1
    Array_X.Add(oPointCol(i)(0))
	Array_Y.Add(oPointCol(i)(1))
Next
Array_X.Sort()
Array_Y.Sort()
minX = Array_X(0)
maxX = Array_X(Array_X.Count-1)
minY = Array_Y(0)
maxY = Array_Y(Array_X.Count - 1)
obx_x = (maxX - minX) 'oriented bounding box X dimension
obx_y = (maxY - minY) 'oriented bounding box Y dimension
obxc_x = ((maxX - minX) / 2) + minX 'oriented bounding box center X measurement
obxc_y = ((maxY - minY) / 2) + minY 'oriented bounding box center Y measurement
obx_counter_X = Round(obx_x / 5)
obx_counter_Y = Round(obx_y/5)
Intercept_X_Counter = 0
For i = 0 To Round(obx_counter_X / 2)
	X_Val = obxc_x - (5 * i)
	Y_Val = obxc_y
	oPoint = oTG.CreatePoint(X_Val/10, Y_Val/10, 0)
	Call InterceptFaceCheck(oPoint, oFace)
	If SharedVariable("InterceptSuccessful") = True Then
		'MessageBox.Show("Ray Intercepted Face: " & oFace.SurfaceBody.Name & vbNewLine & "X: " & Round(X_Val) & ", Y: " & Round(Y_Val))
		Intercept_X_Counter += 1
		If Intercept_X_Counter = 2 Then
			GoTo Start_Y_Intercept
Next
	X_Val = obxc_x + (5 * i)
	Y_Val = obxc_y
Next
Start_Y_Intercept :
Intercept_Y_Counter = 0
For i = 0 To obx_counter_Y
	Y_Val = Round(minY) + (5 * i)
		Intercept_Y_Counter += 1
		If Intercept_Y_Counter = 5 Then
			GoTo Declare_PosX_PosY
Next
Declare_PosX_PosY:
SharedVariable("PosX") = X_Val
SharedVariable("PosY") = Y_Val
'MessageBox.Show("PosX: " & SharedVariable("PosX") & vbNewLine & "PosY: " &  SharedVariable("PosY"))
Array_X.Clear
Array_Y.Clear
End Sub
Sub InterceptFaceCheck(oPoint As Point, oFace As Face)
Dim oVector As UnitVector = oTG.CreateUnitVector(0,0,1) 'Vector direction is in the Z direction
Dim oFoundObjects As ObjectsEnumerator
Dim oFoundPoints As ObjectsEnumerator
Dim oSB As SurfaceBody = oFace.SurfaceBody
oSB.FindUsingRay(oPoint, oVector, 0, oFoundObjects, oFoundPoints)
SharedVariable("InterceptSuccessful") = False
Try
	For Each oLocatedFace As Face In oFoundObjects
		If oFace.SurfaceBody.Name = oLocatedFace.SurfaceBody.Name Then
	Next
Catch
	'No Faces intercepted or unit vector is not normal to the face selected
End Try
End Sub
Sub DXFHeader(File As System.IO.StreamWriter)
' Write DXF header
File.WriteLine("0")
File.WriteLine("SECTION")
File.WriteLine("2")
File.WriteLine("ENTITIES")
End Sub
Sub DXFFooter(File As System.IO.StreamWriter,dxfFilename As String)
' Write DXF footer
File.WriteLine("0")
File.WriteLine("ENDSEC")
File.WriteLine("0")
File.WriteLine("EOF")
' Close the file
File.Close()
If SharedVariable("DXF_Data_Exists") = False Then
	System.IO.File.Delete(dxfFilename)
End Sub
Sub DXFAddText(file As System.IO.StreamWriter, TextToAdd As String, PosX As Double, PosY As Double)
file.WriteLine("  0")
file.WriteLine("TEXT")	'ENTITY TYPE
file.WriteLine("  8")
file.WriteLine("0") 'LAYERNAME
file.WriteLine("100")
file.WriteLine("AcDbText")
file.WriteLine("10")
file.WriteLine(PosX) 'X COORDINATE
file.WriteLine("20")
file.WriteLine(PosY) 'Y COORDINATE
file.WriteLine("30")
file.WriteLine("0.0") ' Z COORDINATE
file.WriteLine("40")
file.WriteLine("3.55") 'TEXT HEIGHT
file.WriteLine("  1")
file.WriteLine(TextToAdd) 'TEXT STRING
file.WriteLine("AcDbText") 'TEXT STRING
End Sub
Sub ExportFace(oFace As Face, File As System.IO.StreamWriter)
Dim oPointCol As New List(Of Double())
For Each oEL As EdgeLoop In oFace.EdgeLoops
	For k = 1 To oEL.Edges.Count
		oEdge = oEL.Edges(k)
		oEdge_StopVertex = oEdge.StopVertex
		oEdge_StartVertex = oEdge.StartVertex
		oEdge_StopVertex_Coordinates = "X" & oEdge.StopVertex.Point.X & "Y" & oEdge.StopVertex.Point.Y & "Z" & oEdge.StopVertex.Point.Z
		oEdge_StartVertex_Coordinates = "X" & oEdge.StartVertex.Point.X & "Y" & oEdge.StartVertex.Point.Y & "Z" & oEdge.StartVertex.Point.Z
'		Dim oHSet As HighlightSet = oDoc.CreateHighlightSet()
'		oHSet.Color = ThisApplication.TransientObjects.CreateColor(185, 0, 0) 'Red
'		oHSet.AddItem(oEdge)
'			MessageBox.Show("Edge type is " & oEdge.GeometryType & vbNewLine & "Start: " & oEdge_StartVertex_Coordinates & vbNewLine & "Stop: " & oEdge_StopVertex_Coordinates)
'		oHSet.Clear()
		If k = 1 Then 'first line in loop
			Try
				oNextEdge = oEL.Edges(k + 1)
				oNextEdge_StopVertex_Coordinates = "X" & oNextEdge.StopVertex.Point.X & "Y" & oNextEdge.StopVertex.Point.Y & "Z" & oNextEdge.StopVertex.Point.Z
				oNextEdge_StartVertex_Coordinates = "X" & oNextEdge.StartVertex.Point.X & "Y" & oNextEdge.StartVertex.Point.Y & "Z" & oNextEdge.StartVertex.Point.Z
			Catch 'There is only 1 edge in the edge loop, does not need to be reversed
				oNextEdge_StopVertex_Coordinates = oEdge_StopVertex_Coordinates
				oNextEdge_StartVertex_Coordinates = oEdge_StartVertex_Coordinates
			End Try
			If oEdge_StopVertex_Coordinates <> oNextEdge_StartVertex_Coordinates And oEdge_StopVertex_Coordinates <> oNextEdge_StopVertex_Coordinates Then 'Current line needs to be reversed
				If oEdge.GeometryType = CurveTypeEnum.kLineCurve Or oEdge.GeometryType = CurveTypeEnum.kLineSegmentCurve Then 'edge is straight
					PointCollection(oPointCol, oEdge_StopVertex.Point.X, oEdge_StopVertex.Point.Y, oEdge_StopVertex.Point.Z, oTG, oSketch, oFace)
					PointCollection(oPointCol, oEdge_StartVertex.Point.X, oEdge_StartVertex.Point.Y, oEdge_StartVertex.Point.Z, oTG, oSketch, oFace)
				Else 'Edge is curved, or spline, polyline, eclipse, ect
					CalculateEdgeStrokes(oEdge, oPointCol, oTG, oSketch, k, oFace, True)
			Else 'Line does not need to be reversed
						PointCollection(oPointCol, oEdge_StartVertex.Point.X, oEdge_StartVertex.Point.Y, oEdge_StartVertex.Point.Z, oTG,oSketch,oFace)
						CalculateEdgeStrokes(oEdge, oPointCol, oTG, oSketch, k, oFace, False)
		Else 'Line is not first line in loop
			If oEdge_StartVertex_Coordinates <> SharedVariable("LastPointCoordinates") Then 'line needs to be reversed
	Next
	If oEL.IsOuterEdgeLoop = True Then
		CalculatePosX_PosY(oPointCol, oFace)
	WritePointsToDXF(File, oPointCol)
	oPointCol.Clear
Next
End Sub
Sub PointCollection(oPointCol As List(Of Double()), X As Double, Y As Double, Z As Double, oTG As TransientGeometry, oSketch As PlanarSketch,oFace As Face)
	SharedVariable("LastPointCoordinates") = "X" & X & "Y" & Y & "Z" & Z
	X_Value = X * 10
	Y_Value = Y * 10
	oPointCol.Add({X_Value, Y_Value})
	'Logger.Debug("X: " & X_Value & ", Y: " & Y_Value)
End Sub
Sub CalculateEdgeStrokes(oEdge As Edge, oPointCol As List(Of Double()), oTG As TransientGeometry, oSketch As PlanarSketch, k As Integer, oFace As Face, ReverseLine As Boolean)
Dim oTempPointCol As New List(Of Double())
Dim lVertexCount As Long
Dim lSegmentCount As Long
Dim adVertexCoords() As Double = {}
Dim alVertexIndices() As Integer = {}
oEdge.CalculateStrokes(0.01, lVertexCount, lSegmentCount, adVertexCoords, alVertexIndices)
j = 1
For i = 0 To adVertexCoords.Length -1
	If j = 1 Then
		strCoord_X = adVertexCoords(i)
	Else If j = 2 Then
		strCoord_Y = adVertexCoords(i)
	Else If j = 3 Then
		strCoord_Z = adVertexCoords(i)
		oTempPointCol.Add({strCoord_X, strCoord_Y, strCoord_Z})
		j = 0	'reset the counter
	j = j + 1
Next
If ReverseLine = False Then
Else 'Reverse line
	oEdge_StartVertex_Coordinates = "X" & oEdge.StopVertex.Point.X & "Y" & oEdge.StopVertex.Point.Y & "Z" & oEdge.StopVertex.Point.Z
strCurrentEdgeStartVertex = "X" & oTempPointCol(0)(0) & "Y" & oTempPointCol(0)(1) & "Z" & oTempPointCol(0)(2)
If strCurrentEdgeStartVertex = oEdge_StartVertex_Coordinates Then
    For i = 0 To oTempPointCol.Count - 1
		'MessageBox.Show("k = 1, point added to collecton. X:" & oTempPointCol(i)(0) & "  Y:" & oTempPointCol(i)(1))
        PointCollection(oPointCol, oTempPointCol(i)(0), oTempPointCol(i)(1), oTempPointCol(i)(2), oTG, oSketch,oFace)
    Next
Else 'Points need to be reversed
    For i = oTempPointCol.Count - 1 To 0 Step -1
    Next
oTempPointCol.Clear
End Sub
Sub WritePointsToDXF(file As System.IO.StreamWriter, oPointCol As List(Of Double()))
SharedVariable("DXF_Data_Exists") = True
' Write lines to file
For i = 0 To oPointCol.Count - 2
    file.WriteLine("0")
    file.WriteLine("LINE")
    file.WriteLine("8")
    file.WriteLine("0")
    file.WriteLine(oPointCol(i)(0))
    file.WriteLine(oPointCol(i)(1))
    file.WriteLine("11")
    file.WriteLine(oPointCol(i+1)(0))
    file.WriteLine("21")
    file.WriteLine(oPointCol(i+1)(1))
Next
' Add the last line to close the shape
file.WriteLine("0")
file.WriteLine("8")
file.WriteLine("0")
file.WriteLine(oPointCol((oPointCol.Count - 1))(0))
file.WriteLine(oPointCol((oPointCol.Count - 1))(1))
file.WriteLine(oPointCol(0)(0))
file.WriteLine(oPointCol(0)(1))
End Sub
