Using iLogic to Create New Sheet and place views
jfenter
Message 1 of 15
jfenter
I want to create an iLogic rule within an idw that will create a Sheet:2 and place a base view and projected view to scale on that new sheet.
The rule would be driven by a parameter in the ipt named "Part_Type".  When the designated part type is active, the rule in the idw would run and create the 2nd sheet, placing the views.  Ideally, I would also like to place some basic dimensions as well but I think that is too advanced for me at this point (especially given I can't even create the sheet:2 now).
I've searched through the forums and found some information, but my knowledge of the API is limited at best.
Part type would be defined as parameter in the ipt.
User would start a new drawing sheet as usual from a template already created with title block, sheet size (C) and border information already defined in sheet:1.
The view style for both the base and projected view would include hidden lines.
The scale would need to be a factor of some value that can be calculated for different sized parts.
Any help would be appreciated.
Replies (14)
Message 2 of 15
Sergio.D.Suárez
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDoc.Sheets(1)
oSheet.Activate
Dim oCommandMgr As CommandManager
oCommandMgr = ThisApplication.CommandManager
' Get control definition for the line command.
Dim oControlDef As ControlDefinition
 oControlDef = oCommandMgr.ControlDefinitions.Item("DrawingNewSheetCtxCmd")
' Execute the command.
Try
oControlDef.Execute
Dim oSheet2 As Sheet
oSheet2 = ThisDoc.Document.ActiveSheet
oSheet2.Name ="Sheet:2"
oSheet2.ExcludeFromPrinting = False
oSheet2.ExcludeFromCount = False
Catch
End Try
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 3 of 15
Sergio.D.Suárez
Hi, Here is an example of a rule that inserts a new sheet, then select a view to insert and then retrieve dimensions and then center them.
You could automatically insert a specific view to fix it in a specific location, but for this purpose all views created with the same initial plane criteria should be included, since the view that would be placed would be "front" and all should be similar. Another situation would arise with the scale, would have to scale the piece automatically in a space of the given sheet. It seemed more correct to me simply to choose it to locate it as one wishes and then to recover automatically the dimensions with which it was created. I hope it is useful. regards
Sub main()
	 add_Sheet
	add_view
	End Sub
Sub add_Sheet
Dim oSheet As Sheet
oSheet.Activate
Try
oControlDef.Execute
oSheet2.Name ="Sheet"
oSheet2.Activate
Catch
End Try
End Sub
Sub add_view
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
Dim oView As DrawingView
 oControlDef = oCommandMgr.ControlDefinitions.Item("DrawingBaseViewCmd")
 oControlDef.Execute2(True)
 'Retrieve Dimensions
For Each oView In oDoc.ActiveSheet.DrawingViews
	Dim oGeneralDimensionsEnum As GeneralDimensionsEnumerator
	oGeneralDimensionsEnum = oSheet.DrawingDimensions.GeneralDimensions.Retrieve(oView)
 Next
 'Center Dimensions
Dim oDrawingDim As DrawingDimension
' Iterate over all dimensions in the drawing and
' center them if they are linear or angular.
For Each oDrawingDim In oSheet.DrawingDimensions
    If TypeOf oDrawingDim Is LinearGeneralDimension Or _
       TypeOf oDrawingDim Is AngularGeneralDimension Then
        Call oDrawingDim.CenterText
Next
 End Sub
Mechanical Designer
Message 4 of 15
jfenter
That works almost exactly as I wanted!  Do you know if there is a way to only dimension certain dimensions?  When I run this rule, I get a lot of redundant dimensions.
Message 5 of 15
Sergio.D.Suárez
If I know, it was an idea that I once proposed in the forum, that you can select a dimension and mark it uncheck it for automatic recovery. I have not yet investigated if you can apply a rule for each type of dimension, any news will warn you
Mechanical Designer
Message 6 of 15
jfenter
One other question that might perfect this code for me.  Can something be added that this rule runs automatically based on a parameter in the ipt?  Only certain part types will require the additional 2D sheet and I would like to have the rule run based on the status of that Part_Type parameter in the model.
Message 7 of 15
jfenter
For some reason, it's bringing in 4 copies of each dimension.
Message 8 of 15
Sergio.D.Suárez
Hello, Excuse me for taking a long time to respond. Here you have a rule that I think does what you are looking for, First you must create a user parameter of the text type, you create multiple value. In my case, the status is "single" and "Sheet 2D". If it is placed on Sheet 2D, the new sheet and the view (s) will be created. You can add the event so that this rule is activated before saving the document. This rule is an animate example to modify and visualize changes. Greetings.
Sub Main ()
On Error Resume Next
Dim oSheet As Sheet
SheetWidth=ActiveSheet.Width/10  'sheet units in cm
SheetHeight = ActiveSheet.Height/10 'sheet units in cm
oTG = ThisApplication.TransientGeometry
oPoint1 = oTG.CreatePoint2d(SheetWidth/2, SheetHeight/2)' view insert point
InventorVb.DocumentUpdate()
 	oView = oDoc.Sheets.Item(1).DrawingViews.Item(1)'firstviewfirstsheet
	oViewScale = oView.Scale
	oViewModelDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
	Dim oParam As Parameter
	oParam=oViewModelDoc.ComponentDefinition.Parameters.Item("Part_Type")
	If oParam.Value = "Sheet 2D" Then
		add_Sheet
		oDoc.Sheets.Item(2).DrawingViews.AddBaseView(oViewModelDoc, oPoint1, oViewScale, ViewOrientationTypeEnum.kFrontViewOrientation, DrawingViewStyleEnum.kShadedDrawingViewStyle, "Default")
																																							'kFromBaseDrawingViewStyle 32260 Derive the Style From the base drawing View.
																																							'kHiddenLineDrawingViewStyle 32257 Hidden line style.
																																							'kHiddenLineRemovedDrawingViewStyle 32258 Hidden lines removed style.
																																							'kShadedDrawingViewStyle 32259 Shaded style (With hidden lines removed).
																																							'kShadedHiddenLineDrawingViewStyle
	 	NewView = oDoc.Sheets.Item(2).DrawingViews.Item(1)
		Dim oCommand As CommandManager
		oCommand = ThisApplication.CommandManager
		oCommand.DoSelect(NewView)
 		oControlDef = oCommand.ControlDefinitions.Item("DrawingViewEditCtxCmd")
		Dim oNewView As DrawingView
		For Each oNewView In oDoc.Sheets.Item(2).DrawingViews
			oGeneralDimensionsEnum = oSheet.DrawingDimensions.GeneralDimensions.Retrieve(oNewView)
		 Next
		 'Center Dimensions
		For Each oDrawingDim In oDoc.Sheets.Item(2).DrawingDimensions
		Next
End Sub
Sub add_Sheet
oDoc = ThisDoc.Document
Dim oSheet As Sheet
oSheet.Activate
Try
oControlDef.Execute
oSheet2.Activate
Catch
End Try
End Sub
Mechanical Designer
Message 9 of 15
jfenter
That doesn't work quite the way I was hoping, but it does place the view and add dimensions.  I was hoping to have the Add Sheet rule run automatically after the part was placed on sheet 1.  The rule would then read the part type from the base view on sheet 1 and determine if sheet 2 was necessary based on the Part_type parameter.  Perhaps my desired result isn't possible with iLogic.  I certainly appreciate all your help with this.
Message 10 of 15
Sergio.D.Suárez
Here is another rule variation. When creating a new drawing file, you execute the rule and insert a view in the default sheet, if the parameter changes as in the previous examples, the sheet will be added and the default dimensions will be added
Mechanical Designer
Message 11 of 15
jfenter
That looks like it would work the way I'm hoping.  Is that activated by an Event Trigger?
Message 12 of 15
Sergio.D.Suárez
Do not.
Try adding event triggers but the rule did not complete the function, so I decided to look for another path, you can try it, where I failed, maybe you can succeed, if you discover the error you can share it so we learn both.
Mechanical Designer
Message 13 of 15
jfenter
what is the code for your last example?
Message 14 of 15
Sergio.D.Suárez
Oh! Excuse me, I thought I had sent it before, greetings!
Sub Main()
Try
	Try
		check_view
	Catch
		Dim CreateBaseView As ControlDefinition
		CreateBaseView = oCommandMgr.ControlDefinitions.Item("DrawingBaseViewCmd")
		CreateBaseView.Execute2(True)
		check_view
	End Try
Catch
End Try
End Sub
Sub check_view
Dim oSheet As Sheet
oPoint1 = oTG.CreatePoint2d(SheetWidth / 2, SheetHeight / 2)' view insert point
 	oView = oSheet.DrawingViews.Item(1)'firstviewfirstsheet
		Try
		oControlDef.Execute
		oSheet2 = oDoc.ActiveSheet
		oSheet2.Activate
		Catch
		End Try
																																							'kShadedDrawingViewStyle 32259 Shaded style (With hidden lines removed).																																					'kShadedHiddenLineDrawingViewStyle
		oCommandMgr.DoSelect(NewView)
		Dim oControlDef2 As ControlDefinition
 		oControlDef2 = oCommandMgr.ControlDefinitions.Item("DrawingViewEditCtxCmd")
 		oControlDef2.Execute2(True)
		 Next
		 'Center Dimensions
		Next
End Sub
Mechanical Designer
Message 15 of 15
ria.markides
Observer
Observer
Hi, the information on this thread is very useful. Any updates on the topic of only displaying certain dimensions?
