Using iLogic to create a linear dimension between two ProxyWorkPoint's
harvey_craig2RCUH
harvey_craig2RCUH
As the title, I have created proxy work points and I wish to create a linear dimension between them. The gap in my knowledge is how I turn the WorkPointProxy's into a GeometeryIntent's.
Dim oModelDoc = ActiveSheet.View(viewname).ModelDocument
Dim oAssemblyDoc As AssemblyDocument = oModelDoc
Dim oPartOcc = oAssemblyDoc.ComponentDefinition.Occurrences.ItemByName("my part") 'Name of part in assembly
Dim oPartDoc As PartDocument = oPartOcc.Definition.Document
Dim oNamedEntities = iLogicVb.Automation.GetNamedEntities(oPartDoc)
oDetailView = oSheet.DrawingViews.Item(2)'1 for main view, 2 for detail view.
Dim oGenDims As GeneralDimensions = oSheet.DrawingDimensions.GeneralDimensions
Dim oWPN3 As WorkPoint = oNamedEntities.FindEntity("WPN3")
Dim oWPN3Proxy As WorkPointProxy
oPartOcc.CreateGeometryProxy(oWPN3, oWPN3Proxy)
Dim oWPN2 As WorkPoint = oNamedEntities.FindEntity("WPN2")
Dim oWPN2Proxy As WorkPointProxy
oPartOcc.CreateGeometryProxy(oWPN2, oWPN2Proxy)
oGenDims.AddLinear(oTG.CreatePoint2d(5,5), oWPN2, oWPN3)
If you look at the last line I have inserted two WorkPointProxy's as my GeometryIntent's. I know this is wrong. How do I make the conversion to the correct data type?
Many thanks,
Harvey
AndrewHumiston
GOOD MORNING!
Here is a snippet of code i used to find the proxy on a 'shelf' object and then create the geometry intent with proxy plane for creating a dim.
I'm a little busy at work at the moment, but hopefully this helps you sort it out.
'set ref to each shelf
Dim Assembly As ComponentOccurrence
For Each Assembly In ModelFile.ComponentDefinition.Occurrences
	If InStr(Assembly.Name, "Shelf") >= 1 Then
		For Each WPlane In Assembly.Definition.WorkPlanes
			If WPlane.Name = "Top" Then
				Dim ShelfProxy As WorkPlaneProxy
				Assembly.CreateGeometryProxy(WPlane, ShelfProxy)
				Dim oShelfIntent As GeometryIntent
				oWorkSurface = oActiveSheet.Centerlines.AddByWorkFeature(ShelfProxy, DrawingView)
				oShelfIntent = oActiveSheet.CreateGeometryIntent(oWorkSurface, kEndPointIntent)
				oWorkSurface.Visible = False
				Call oDimGeoIntent.Add(oShelfIntent)
				Exit For
		Next
Next
harvey_craig2RCUH
I have created similar example due to the copyright nature of the original. This is what I would like to do in the UI:
I have attached all the files if someone would like to have a look.
Harvey
