Using Ilogic to add a new member to my Iassembly
systemerorr41
systemerorr41
 Hi All 🙂
I have an Iassembly.
Data about width / depth / height of a box get automatically imported by an Ilogic rule.
I'd like the ilogic rule to automatically create a new member in the Iassembly every time new data gets imported.
How can I create a new member in an Iassembly using Ilogic?
dalton98
I haven't worked much with iAssemblies so I'm confused about what your asking. Would you like to place a new component with the desired l/w/h. or add a new row to the iAssembly table with l/w/h?
systemerorr41
Thanks for replying! 🙂
Sorry for the confusion, it's indeed 'adding a new row to the iAssembly table with l/w/h'
dalton98
I used this blog post
https://modthemachine.typepad.com/my_weblog/begging-api/page/2/
This example was used on an iPart but I assume it works the same way
Before:
Code:
Dim oFactoryDoc As PartDocument
oFactoryDoc = ThisApplication.ActiveDocument
Dim oPartFactory As iPartFactory
oPartFactory = oFactoryDoc.ComponentDefinition.iPartFactory
oWS = oPartFactory.ExcelWorkSheet
oWS.Cells(3, 1) = "Vise_Screw-02"
oWS.Cells(3, 2) = "Vise_Screw-02"
oWS.Cells(3, 3) = "vise_screw_length - 58.737 mm"
oWS.Cells(3, 4) = "200 mm"
oWS.Parent.Save
oWS.Parent.Close
After:
dalton98
@systemerorr41 Also to get the number of rows in the iassembly you would do:
oRows = oPartFactory.TableRows.Count + 1
