Using iLogic for Idealization Shell
I want to use iLogic to create a Shell Idealization and can't find a way to get it work.
When running the rules I get an error "Mesh does not contains any nodes or elements" and I think its this row of code that is the problem:
 strCmdForNewIdealization = "<NewIdealization Name=""Test Shell 1"" ID=""1"" Type=""1"" AddToFEModel=""1"" Color=""11087083"" CoordinateSystemID=""0"" MaterialID=""1"" EntitiesCount=""0""/>"
I copied it from an turtorial example but instead of using Shell it used Solid. So I changed it from Type = "2" (solid) to Type = "1" (Shell) accoring to this website:
https://knowledge.autodesk.com/support/nastran-cad/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/N...
What could be the problem?
When apply an Idealization "manually" and not using iLogic you have to define the thickness of the Shells and I don't know how to do it in iLogic.
Thanks in advance!
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
When it comes to iLogic programming needs and question please post over in the Inventor customization forum https://forums.autodesk.com/t5/inventor-customization/bd-p/120 for best results.  I will have the moderator relocate your posting there to best suit your needs.
Mark Lancaster
