Using Custom iProperties To Build The Part Number (In iProperties)
Hi Everyone,
First off, thanks for clicking on this post with the intention of trying to help.  you are all rockstars that have helped me out of more than enough jams in the past.  hopefully, someone can help me here as well.
I'm looking to create a Part Number Generator at the drawing level using iProperties and Parameters.  the end result would be having a part number that looks like this;
ABC-123-ABC123-123
My original idea was to create fill in 4 fields in a form and use the following code to fill in the Part Number field in iProperties.
=<DWG_TYPE>-<PRODUCT_TYPE>-<PRODUCT_NUMBER>-<SA_NUMBER>
iLogic Code Driving some specifics
iProperties.Value("Project", "Part Number") = "=AS-<PRODUCT_TYPE>-<PRODUCT_NUMBER>"
'Drawing Type Options
'Assemblies
If DRAWING_TYPE = "Assemblies" And SUB_ASSEMBLY = 0 Then
ElseIf DRAWING_TYPE = "Assemblies" And SUB_ASSEMBLY >= 1 Then
iProperties.Value("Project", "Part Number") = "=AS-<PRODUCT_TYPE>-<PRODUCT_NUMBER>-<SUB_ASSEMBLY>"
'Builds
ElseIf DRAWING_TYPE = "Builds" And SUB_ASSEMBLY = 0 Then
iProperties.Value("Project", "Part Number") = "=BD-<PRODUCT_TYPE>-<PRODUCT_NUMBER>"
ElseIf DRAWING_TYPE = "Builds" And SUB_ASSEMBLY <= 1 Then
iProperties.Value("Project", "Part Number") = "=BD-<PRODUCT_TYPE>-<PRODUCT_NUMBER>-<SUB_ASSEMBLY>"
'Design
ElseIf DRAWING_TYPE = "Design" And SUB_ASSEMBLY = 0 Then
iProperties.Value("Project", "Part Number") = "=DE-<PRODUCT_TYPE>-<PRODUCT_NUMBER>"
ElseIf DRAWING_TYPE = "Design" And SUB_ASSEMBLY <= 1 Then
iProperties.Value("Project", "Part Number") = "=DE-<PRODUCT_TYPE>-<PRODUCT_NUMBER>-<SUB_ASSEMBLY>"
'Electrical
ElseIf DRAWING_TYPE = "Electrical" And SUB_ASSEMBLY = 0 Then
iProperties.Value("Project", "Part Number") = "=EL-<PRODUCT_TYPE>-<PRODUCT_NUMBER>"
ElseIf DRAWING_TYPE = "Electrical" And SUB_ASSEMBLY <= 1 Then
iProperties.Value("Project", "Part Number") = "=EL-<PRODUCT_TYPE>-<PRODUCT_NUMBER>-<SUB_ASSEMBLY>"
'Fabrication
ElseIf DRAWING_TYPE = "Fabrication" And SUB_ASSEMBLY = 0 Then
iProperties.Value("Project", "Part Number") = "=FB-<PRODUCT_TYPE>-<PRODUCT_NUMBER>"
ElseIf DRAWING_TYPE = "Fabrication" And SUB_ASSEMBLY <= 1 Then
iProperties.Value("Project", "Part Number") = "=FB-<PRODUCT_TYPE>-<PRODUCT_NUMBER>-<SUB_ASSEMBLY>"
'Layout
ElseIf DRAWING_TYPE = "Layout" And SUB_ASSEMBLY = 0 Then
iProperties.Value("Project", "Part Number") = "=LA-<PRODUCT_TYPE>-<PRODUCT_NUMBER>"
ElseIf DRAWING_TYPE = "Layout" And SUB_ASSEMBLY <= 1 Then
iProperties.Value("Project", "Part Number") = "=LA-<PRODUCT_TYPE>-<PRODUCT_NUMBER>-<SUB_ASSEMBLY>"
'Modules
ElseIf DRAWING_TYPE = "Modules" And SUB_ASSEMBLY = 0 Then
iProperties.Value("Project", "Part Number") = "=MOD-<PRODUCT_TYPE>-<PRODUCT_NUMBER>"
ElseIf DRAWING_TYPE = "Modules" And SUB_ASSEMBLY <= 1 Then
iProperties.Value("Project", "Part Number") = "=MOD-<PRODUCT_TYPE>-<PRODUCT_NUMBER>-<SUB_ASSEMBLY>"
'Parts
ElseIf DRAWING_TYPE = "Parts" And SUB_ASSEMBLY = 0 Then
iProperties.Value("Project", "Part Number") = "=PT-<PRODUCT_TYPE>-<PRODUCT_NUMBER>"
ElseIf DRAWING_TYPE = "Parts" And SUB_ASSEMBLY <= 1 Then
iProperties.Value("Project", "Part Number") = "=PT-<PRODUCT_TYPE>-<PRODUCT_NUMBER>-<SUB_ASSEMBLY>"
'Engineering Review
ElseIf DRAWING_TYPE = "Engineering Review" And SUB_ASSEMBLY = 0 Then
iProperties.Value("Project", "Part Number") = "=RE-<PRODUCT_TYPE>-<PRODUCT_NUMBER>"
ElseIf DRAWING_TYPE = "Engineering Review" And SUB_ASSEMBLY <= 1 Then
iProperties.Value("Project", "Part Number") = "=RE-<PRODUCT_TYPE>-<PRODUCT_NUMBER>-<SUB_ASSEMBLY>"
'Set Up
ElseIf DRAWING_TYPE = "Set Up" And SUB_ASSEMBLY = 0 Then
iProperties.Value("Project", "Part Number") = "=SE-<PRODUCT_TYPE>-<PRODUCT_NUMBER>"
ElseIf DRAWING_TYPE = "Set Up" And SUB_ASSEMBLY <= 1 Then
iProperties.Value("Project", "Part Number") = "=SE-<PRODUCT_TYPE>-<PRODUCT_NUMBER>-<SUB_ASSEMBLY>"
'Product Type
'Energy
If PRODUCT_OPTIONS = "Energy" Then
PRODUCT_TYPE = 100
ElseIf PRODUCT_OPTIONS = "Energy - Solar" Then
PRODUCT_TYPE = 101
ElseIf PRODUCT_OPTIONS = "Energy - Enclosures" Then
PRODUCT_TYPE = 102
ElseIf PRODUCT_OPTIONS = "Energy - Accessory" Then
PRODUCT_TYPE = 103
'Electrical
ElseIf PRODUCT_OPTIONS = "Electrical" Then
PRODUCT_TYPE = 200
ElseIf PRODUCT_OPTIONS = "Electrical - Skid" Then
PRODUCT_TYPE = 201
ElseIf PRODUCT_OPTIONS = "Electrical - Enclosures" Then
PRODUCT_TYPE = 202
ElseIf PRODUCT_OPTIONS = "Electrical - Accessory" Then
PRODUCT_TYPE = 203
ElseIf PRODUCT_OPTIONS = "Electrical - E-House" Then
PRODUCT_TYPE = 210
ElseIf PRODUCT_OPTIONS = "Electrical - MTS Builds" Then
PRODUCT_TYPE = 220
'Structural
ElseIf PRODUCT_OPTIONS = "Structural" Then
PRODUCT_TYPE = 300
'Specialty
ElseIf PRODUCT_OPTIONS = "Specialty" Then
PRODUCT_TYPE = 900
However, as you may have guessed, the code above only works if the parameters are exportable and parameters at the drawing level are not.  I tried replacing;
with;
iProperties.Value("Project", "Part Number") = "=AS-<PRODUCT_TYPE>-<iProperties.Value("Custom", "Product Name")>"
That only results in the following error;
Rule Compile Errors in P/N Generator, in Part16
Error on Line 1 : Character constant must contain exactly one character.
I think that I am close to figuring this out but, I've hit a wall.  Is there a way to create custom iProperites to preform the same function as the parameters?
Paul
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Below code may be helpful.
iProperties.Value("Project", "Part Number") = "=AS-<PRODUCT_TYPE>-" + iProperties.Value("Custom", "Product Name")
To reproduce the error, can you please provide non confidential drawing data?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Thank you for your help.  That bit of code helped a lot.  However, I am not able to figure out how to run that code with multiple iproperty fields seperated by "-".
When I try
iProperties.Value("Project", "Part Number") = "=AS-" + iProperties.Value("Custom", "PRODUCT TYPE") + iProperties.Value("Custom", "PRODUCT NUMBER")
 I get AS-123ABC when I'm hoping for AS-123-ABC.
My attempts to solve this only run into errors like
Conversion from string "ABC" to type 'Double' is not valid.
or
Error on Line 1 : End of statement expected.
I am unable to send you an example of the drawing file as it is now.  However,  I think once I figure out the dash issue, I'll be ready to go.  If needed, I'll see about creating a drawing with all the code in it that lack company information.
Thanks again for your help.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous ,
Try below iLogic code to get desired part number as "AS-123-ABC".
iProperties.Value("Project", "Part Number") = "=AS-" + iProperties.Value("Custom", "PRODUCT TYPE").ToString + "-" + iProperties.Value("Custom", "PRODUCT NUMBER")
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
I see what I did wrong.  thank you very much for your help.
