Using Apprentice to open .idw in IV2008
Message 1 of 12
Any changes needed to make for using apprentice to open .idw file
I have no problem with .ipt and iam. however, when I tried to open .idw with
apprentice, I got runtime error '-214748113(8000fffff)':
method '~' of object '~' failed
Thx, CVA
www.CVAengineering.com
IV11 Pro. sp2 and IV2008
Window XP Pro sp2
Pentium 3.2 Ghz, 3.0 GB of RAM
NVIDIA FX 3400 84.26
SpacePilot V 3.3.6
Replies (11)
Message 2 of 12
Would someone from Autodesk confirm this?
Thx, CVA
Window XP Pro sp2
SpacePilot V 3.3.6
"CVAengineering" wrote in message
news:5628283@discussion.autodesk.com...
Thx, CVA
Window XP Pro sp2
SpacePilot V 3.3.6
Message 3 of 12
Ok... I am able to locate where the error came from (please see the att.) -
Hopefully, it'd give you guys a hints
Thx, CVA
Window XP Pro sp2
SpacePilot V 3.3.6
news:5629310@discussion.autodesk.com...
Thx, CVA
Window XP Pro sp2
SpacePilot V 3.3.6
Thx, CVA
Window XP Pro sp2
SpacePilot V 3.3.6
Message 4 of 12
Just a wild guess, but oAppDocIdw is neither
dimensioned nor declared.  Try "Option Explicit".
brian r
iwaskewycz
style="FONT-SIZE: 14pt; FONT-FAMILY: Verdana">cad systems
manager
href="http://www.corefurnace.com/">core furnace
systems
Message 5 of 12
Actually, it has been declared as a global variable
I guess the counting number of sheets caused error
here
CVA
Window  XP Pro  sp2
Pentium 3.2
Ghz, 3.0 GB of RAM
SpacePilot  V
3.3.6
brian r
iwaskewycz
manager
systems
Message 6 of 12
This appears to be a case specific issue.  I
just wrote a simple program to test it and am able to get the sheet count
without any problem.  I tested it with a few different drawings, from
different versions of Inventor, and they all worked fine.  Is this
happening for all cases for you?  Can you post a drawing that's
demonstrating this problem?
Brian Ekins
Autodesk Inventor
API
Message 7 of 12
Brian,
I got the same error mesg even though I tried to
open a template ansi .idw file
CVA
Window  XP Pro  sp2
Pentium 3.2
Ghz, 3.0 GB of RAM
SpacePilot  V
3.3.6
Brian Ekins
Autodesk Inventor
API
Message 8 of 12
and yes, my program works fine for all other
previous releases until now, IV2008
Window  XP Pro  sp2
Pentium 3.2
Ghz, 3.0 GB of RAM
SpacePilot  V
3.3.6
Brian,
CVA
Window  XP Pro  sp2
Pentium 3.2
Ghz, 3.0 GB of RAM
SpacePilot  V
3.3.6
I just wrote a simple program to test it and am able to get the sheet count
Brian Ekins
Autodesk Inventor
API
Message 9 of 12
Here's the VB 6 source from the sample I wrote to
test this.  Can you try this to and see if it works or not for
you?
Private Sub Command1_Click()
Dim oApprentice As New ApprenticeServerComponent
    Dim oDoc
As ApprenticeServerDrawingDocument
    Set oDoc =
oApprentice.Open("C:\Temp\Drawing.idw")
    Debug.Print oDoc.NeedsMigrating
Debug.Print oDoc.Sheets.Count
    Dim
oSheet As Inventor.Sheet
    For Each oSheet In
oDoc.Sheets
        Debug.Print
oSheet.Name
    Next
End Sub
Brian
Ekins
Autodesk Inventor API
Message 10 of 12
I got the same error msg as above
CVA
Window  XP Pro  sp2
Pentium 3.2
Ghz, 3.0 GB of RAM
SpacePilot  V
3.3.6
you?
Private Sub
Command1_Click()
    Dim oDoc As
    Set oDoc =
    Dim
    For Each oSheet In
oDoc.Sheets
        Debug.Print
oSheet.Name
    Next
End Sub
Brian
Ekins
Message 11 of 12
Brian,
If I rename the sheet in the .idw file, then the
program works ok. However, I the file has more than on sheet and it has default
sheet name such as Sheet:1, Sheet:2, then I got a runtime error
CVA
Window  XP Pro  sp2
Pentium 3.2
Ghz, 3.0 GB of RAM
SpacePilot  V
3.3.6
you?
Private Sub
Command1_Click()
    Dim oDoc As
    Set oDoc =
    Dim
    For Each oSheet In
oDoc.Sheets
        Debug.Print
oSheet.Name
    Next
End Sub
Brian
Ekins
Message 12 of 12
Ouch...
It seems that the TrueConnect implementation (which
requires unique sheet names) is the cause for even more grief...
T. Ham
CAD Automation & Systems
Administrator
CDS Engineering BV
HP xw4300 Workstation
Dual Pentium XEON 3.6 Ghz
4 GB SDRAM
NVIDIA
QUADRO FX 3450/4000 SDI (Driver = 8.4.2.6)
250 GB SEAGATE SATA Hard
Disc
3Com Gigabit NIC
Windows XP Professional SP2
Autodesk Inventor Series 10
SP3a
