Using API to Sort Drawing Sheets
inulobo
inulobo
I am stuck. I am not sure where I am going wrong. I am trying to sort the drawing sheets by name alphanumerically. Looking for some input. I am trying to do it with a collection.
Sub Sort_DrawingSheets()
    Dim drawingDoc As DrawingDocument
    'Set drawingDoc = ThisDoc.Document
    Set drawingDoc = ThisApplication.ActiveDocument
    Dim sheet As sheet
    Dim oSheets As Sheets
    Set oSheets = drawingDoc.Sheets
    Dim sheetsList As New Collection
    Set sheetsList = New Collection
    Dim vTemp As Variant
    Dim browserPane As browserPane
    Set browserPane = drawingDoc.BrowserPanes.item("Model")
    For Each sheet In oSheets
        sheetsList.Add (sheet.Name)
    Next
    For i = 1 To sheetsList.Count - 1
        For j = i + 1 To sheetsList.Count
            If sheetsList.item(i) > sheetsList.item(j) Then
                vTemp = sheetsList.item(j)
                sheetsList.Remove j
                sheetsList.Add vTemp, vTemp, i
            End If
        Next j
    Next i
    For Each sheet In sheetsList
        Dim sheetNode As BrowserNode
        Set sheetNode = browserPane.GetBrowserNodeFromObject(sheet)
        Dim bottomNode As BrowserNode
        Set bottomNode = browserPane.TopNode.BrowserNodes.item(browserPane.TopNode.BrowserNodes.Count)
        Call browserPane.Reorder(bottomNode, False, sheetNode)
    Next
End Sub
inulobo
Nevermind figured it out. Cannot use a regular collection needed object collection.
