Using API, change centerlines to sketchlines
Hi everyone,
I have created these all sketch lines using Inventor API.
oLines  = oSketch1.SketchLines.AddByTwoPoints(oTransGeom.CreatePoint2d(startpointX,startpointY), oTransGeom.CreatePoint2d(endPointX,endPointY));
Now I want change  the line (circled in red color) in centerlines. And this is how I have done:
ObjectCollection oFitPoints = mInventorApp.TransientObjects.CreateObjectCollection();
Point2d oPoint1 = oTransGeom.CreatePoint2d(3, 5);
oFitPoints.Add(oPoint1);
Point2d oPoint2 = oTransGeom.CreatePoint2d(4, 0);
oFitPoints.Add(oPoint2);
Centerlines oCenterLines = default(Centerlines);
oCenterLines.Add(oFitPoints, ObjectTypeEnum.kLinearGeneralDimensionObject, LineTypeEnum.kLongDashDottedLineType, false);
Since the centerlines couldn’t be add in the sketch lines I got the null exception error.
So, how do I change centerlines into sketch lines so that I could draw it using API.
Suggest me please.
With regards,
Prarthana
Curtis_Waguespack
Hi 15985329236,
Here's a quick example of toggling a line to/from a centerline type.
I hope this helps.
Curtis
' Get the first item in the select set.
'This assumes a line is selected
Dim oSketchEnt As SketchEntity
Try
oSketchEnt = ThisApplication.ActiveDocument.SelectSet.Item(1)
Catch
MessageBox.Show("Select a line, and only a line.", "iLogic")
Return
End Try
Dim oLine As SketchLine
oLine = oSketchEnt
' Toggle the centerline property.
If oLine.Centerline Then
	oLine.Centerline = False
Else
	oLine.Centerline = True
Thank you very much. 🙂
Act. I had opened the forum to post the same answer which I did it by myself in the same way
and saw your post 🙂
Thank you for your help.
