UserParamter
UserParamter
GeorgK
Advisor Advisor
UserParamter
GeorgK
Hello together,
I create a Userparamter:
Public Sub CreateTextUserParameter()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oUserParameters As UserParameters
    Set oUserParameters = oDoc.ComponentDefinition.Parameters.UserParameters
    Dim oTextParam As UserParameter
    Set oTextParam = oUserParameters.AddByValue("Printer_Name", "3DPrinter", kTextUnits)
End Sub
This does not work:
Dim oParam As Parameter
        For Each oParam In doc.ComponentDefinition.Parameters
            If oParam.Name = "Printer_Name"  Then
                If oParam.Expression = "3DPrinter" Then
                               MsgBox(oParam.Expression)
        Next
But how could I check if the value exists and get the textvalue?
Thank you Georg
Kindly find the code below which works
doc = ThisApplication.ActiveDocument
MsgBox(oParam.Name +" -- " +oParam.Expression)
If oParam.Expression = """3DPrinter""" Then
Next
GeorgK
Thak you very much. That solves the problem.
