userparams.addbyvalue: how is this work?
Message 1 of 8
Hello!
I have to add a lot of userparameters to a batch of parts. Userparams name, value and units will be the same for each parts so I'm trying to write a program that will do this boring job for me but I don't know how work the addbyvalue method and I did'nt find explicit samples in IV. Someone can help?
Sword
Venmar CES inc.
Replies (7)
Message 2 of 8
Here's some sample code that demonstrates the use
of this function and the AddByExpression function.  The input value for the
AddByValue function is always database units for the unit type specified.
For example in the first two calls to AddByValue below, they are defining a
distance.  The internal database units for distance within Inventor are
centimeters, so distance values passed into the AddByValue function will always
be assumed to be centimeters.  The unit argument allows you to set the unit
associated with the parameter.  The unit argument is the equivalen of the
Unit column in the parameters dialog.  For example, the first call creates
a parameter that has a value of 2.54 centimeters but will use an inch
unit. In the parameters dialog this results in a display of a parameter of
1 inch.  For a more complete discussion of the units see the Units of
Measure section in the online help.
The AddByExpression function is the equivalent to
creating an parameter interactively through the dialog.  In this case,
instead of a value you specify a string.  This string can contain unit
information and equations.  For example you could provide input like "5 in
+ 3 cm" or "Dist1 / 2.0".
Public Sub AddParams()
    ' Get
a reference to the active part document.
    Dim oDoc As
PartDocument
    Set oDoc =
ThisApplication.ActiveDocument
    With
oDoc.ComponentDefinition.Parameters.UserParameters
' Create two parameters using distance units and
value.
        Call .AddByValue("Dist1",
2.54, "in")
        Call
.AddByValue("Dist2", 2.54, "cm")
distance units and expression.
Call .AddByExpression("Dist3", "1",
"in")
        Call
.AddByExpression("Dist4", "2.54",
"cm")
angle units and value.
        Call
.AddByValue("Angle1", 3.14, "deg")
Call .AddByValue("Angle2", 3.14,
"rad")
angle units and expression.
        Call
.AddByExpression("Angle3", "180",
"deg")
        Call
.AddByExpression("Angle4", "3.14", "rad")
    End With
End
Sub
-Brian
Hello!
Sword
Venmar CES inc.
Message 3 of 8
Thanks for your help!
Sword
Message 4 of 8
Brian (or anybody who know how to do it), could please tell me if it is possible to programmatically export parameters? With your previous example, I'm now able to create new params, give it new value or expression and set the unit of measure...Only "how to export it" is missing!:)
Sword
Message 5 of 8
There is the ability to iterate through all of the
parameters and to query all of their information so to export them the real
question is where do you want the data and what specific information do you
need.  You could choose to export them to a simple text file, or define an
XML format, or write them to an Excel spreadsheet, or write them into an Access
database, or probably a hundred other things.  Here's a simple program that
write all of the parameters to a comma delimited text file.
Public Sub WriteParamters()
Get a reference to the parameters collection.  This will
fail
    ' if a part or assembly document is not
active.
    On Error Resume Next
    Dim
oParams As Parameters
    Set oParams =
ThisApplication.ActiveDocument.ComponentDefinition.Parameters
If Err Then
        MsgBox "A part or
assembly document must be active."
Exit Sub
    On Error GoTo
0
    ' Open the text file.  If
the file exists it will overwrite it.
    Open
"C:\Temp\Params.txt" For Output As #1
    ' Iterate through the parameters
and write out information
    Dim oParam As
Parameter
    For Each oParam In
oParams
        Dim strData As
String
        Print #1, oParam.Name &
", " & oParam.Expression & ", " & oParam.Value & ", " &
oParam.Units & ", """ & oParam.Comment & """"
Next
    ' Close the
file
    Close #1
End Sub
-Brian
Brian
Sword
Message 6 of 8
thanks for the answer but it's not really what i'm looking for. I need to programmatically check the "export checkbox" in the paramaters table. This way, parameters will be transpose as "text custom properties" and I will be able to use it in an idw...
Sword
Message 7 of 8
Just set the ExposedAsProperty to True for the
property you want to export.
-Brian
thanks
Sword
Message 8 of 8
thanks again!
