UserParameter Error
UserParameter Error
NachoShaw
Advisor Advisor
UserParameter Error
NachoShaw
Hey
Im getting thrown an error in my function. I have a User Parameter in my part called CONVERT_FT and its unit is set to ft. Here is my code
Friend Function QuantifyLengthAsFT(ByVal length As String) As String
            Dim ret As String = String.Empty
            Dim oParams As UserParameters = CType(_BMDef.Parameters.UserParameters, UserParameters)
            Dim ParameterUnits As UnitsTypeEnum = UnitsTypeEnum.kFootLengthUnits
            Try
                Dim P As UserParameter = oParams.Item("CONVERT_FT")
                P.Expression = length
                Dim r As Double = CType(oParams.Item("CONVERT_FT").Value, Double)
                ret = ConvertValueToFT(CType(r, Double)) & " " & P.Units
                P.Expression = "0 ft"
            Catch ex As Exception
                ret = "Not Value"
            End Try
            Return ret
        End Function
(Assume _BMDef is a ComponentDefinition)
As i step through the function, the error is thrown on this line
and the error is
{The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))"}
I have another similar function with the unit as inches and that doesnt have an error
Any ideas?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
NachoShaw
figured it out, i was using the wrong document...
Nacho
