User text parameters work with model states
michal.skubik
michal.skubik
Hello, is it possible modify code bellow to work with model states? Any ideas?
Dim
oDoc As Document = ThisApplication.ActiveDocument Dim OComp As ComponentDefinition = oDoc.ComponentDefinition Dim oUPs As UserParameters = OComp.Parameters.UserParameters Dim oUP As UserParameter Dim xlsFile As String = "c:\_WORK_AV\Engineering\_Invdata\iLogic\Category.xls" GoExcel.Open(xlsFile, "Sheet1") Dim i As Integer = 2 Dim Param As String Dim List As IList Do Until i = 100 Param = GoExcel.CellValue ("A" & i) If Param = "" Then Exit Do List = GoExcel.CellValues("B" & i, "L" & i) Try Test = oUPs.Item(Param) Catch oUP = oUPs.AddByValue(Param, GoExcel.CellValue("B" & i), UnitsTypeEnum.kTextUnits) End Try MultiValue.List(Param) = List i = i + 1 Loop
dalton98
Edit: You might have to change your way of going about it. Every parameter is shared on a model stated part/assembly. So, you would have to create a multi value parameter and assign its values to each model state. Your second parameter that is already a multi-valued is not possible as far as I know.
