User Parameter: How to retrieve Dimension Text Box Text
RoyWickrama_RWEI
Advisor Advisor
RoyWickrama_RWEI
I need to retrieve the user parameter text box information with an iLogic code.
Please see below (sample ipt added):
User para.pngI Request someone help me.
Also, how can I distinguish a model parameter from a user parameter?
Note: Currently, I manually type in the user-parameter name. (In this regard, the selected dimension need not to be the parameter I type in).
Thanks.
RodrigoEiras
I think you can get the parameter name from the dimension using: parameter.Expression
Something like this:
SyntaxEditor Code Snippet
Dim p As Parameter
p = Parameter.Param("d0")
trace.writeline(p.Expression)
I hope it helps.
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI,
Hoping that below iLogic code would help to get user parameter name of selected dimension.
Sub Main()
	Dim oSelectedDim As DimensionConstraint
	oSelectedDim = ThisApplication.Commandmanager.Pick(SelectionFilterEnum.kSketchDimConstraintFilter,"Select a dimension to change dimension")
    If oSelectedDim.Parameter.DrivenBy.Count > 0 Then
        Dim oUserParam As UserParameter
        oUserParam = oSelectedDim.Parameter.DrivenBy.Item(1)
	MsgBox ("User parameter name is '" & oUserParam.Name & "'")
    Else
        MsgBox ("Selected dimension is not contianing any user parameter")
	iLogicVb.UpdateWhenDone = True
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
RoyWickrama_RWEI
Hi Chandra Shekar Gopal;
Great piece of code and GREAT HELP. I am getting what I need to do.
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
Dim oParameter As Parameter
'	MsgBox ("User parameter name is '" & oUserParam.Name & "'")
	oText = ""
	x = 0
	100:
	If x >0 Then oText = "HIT OK BUTTON"
	oUP_Edit_X = InputBox("REVISE USER PARAMETER: " _
	& vbLf & "" _
	& vbLf & oText, "PARAMETER NAME", oUserParam.Name)
	If oUP_Edit_X = "" Then
	x += 1
	Goto 100:
	On Error Resume Next
	Parameter(oUP_Edit_X) = InputBox("Current Value", "USER PARAMETER EDIT: " & oUP_Edit_X, Parameter(oUP_Edit_X))
	Else
End Sub
RoyWickrama_RWEI
Thanks for the reply.
I have not so far done any thing using:
I shall be most grateful in case you provide me with a complete code for using the above.
