USer Event when user locks a View/ DesignViewReperesentation
Holzethekid
Holzethekid
Hallo,
a am searching for an event on the api which tells me when a user locks/unlock  a view.
What i found out so far is that the kDefaultCommand is executed when clicking the btn.
application.CommandManager.UserInputEvents.OnStartCommand += OnStartCommand;
private void OnStartCommand(CommandIDEnum commandid)
   logger.Debug($"OnStartCommand {commandid}");
So does any one know how to achieve this ?
My current solution would be :
    if (app.ActiveDocument is PartDocument part)
        foreach (DesignViewRepresentation designViewRepresentation in part.ComponentDefinition.RepresentationsManager.DesignViewRepresentations)
            if (viewLockedStatus.ContainsKey(designViewRepresentation.Name))
                if (viewLockedStatus[designViewRepresentation.Name] != designViewRepresentation.Locked)
                    viewLockedStatus[designViewRepresentation.Name] = designViewRepresentation.Locked;
                    Messenger.Default.Send(new ViewLockStatusChangedMessage(designViewRepresentation.Name));
            else
                viewLockedStatus.Add(designViewRepresentation.Name, designViewRepresentation.Locked);
Thanks in advance
Christian
JelteDeJong
You should have at the OnDocumentChange event. It will fire on all changes. But you can check the context parameter it will tell you the internal name of the command that caused the change. (This name will be consistent regardless of the current language.)
Class MyClass
    Private appEvents As ApplicationEvents
    Sub Main()
        appEvents = ThisApplication.ApplicationEvents
        AddHandler appEvents.OnDocumentChange, AddressOf AppEvents_OnDocumentChange
    End Sub
    Private Sub AppEvents_OnDocumentChange(DocumentObject As _Document, BeforeOrAfter As EventTimingEnum, ReasonsForChange As CommandTypesEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum)
        HandlingCode = HandlingCodeEnum.kEventNotHandled
		If (Context.Item("InternalName") = "LockDesignView") Then
            MsgBox($"Someone clicked the lock button.")
    End Sub
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
Holzethekid
Hallo JelteDeLong,
thank you for your  answer. In my case the name changed to 'UCLockDesignView'.
The current snipped works on Inventor Pro. 2022.2
private void OnDocumentChanged(_Document documentobject, EventTimingEnum beforeorafter, CommandTypesEnum reasonsforchange, NameValueMap context, out HandlingCodeEnum handlingcode)
      if ((string)context.Item["InternalName"] == "UCLockDesignView")
          Messenger.Default.Send(new ViewLockStatusChangedMessage("Bla"));
      handlingcode = HandlingCodeEnum.kEventHandled;
