User Defined Symbol with Quantity
When we create assembly prints we add a note to each part/assembly with the following format:
3/8" SS FLAT WASHER
021-0033 (4X)
or
3/8" SS FLAT WASHER
021-0033
The first being used if there are multiple instances in the view, the second being used if there is only one.
The parts all should have properties that they pull this infomration from <DESCRIPTION>, <PART NUMBER> but then the user needs to enter the number of instances.
I tried creating a custom user symbol but cannot combine the properties with a prompted entry.
I don't mind having a seperate symbol for either format of the note or using a 1X for the single instance symbol.
So my question is, can I create a user created symbol that combines file properties with a prompted entry in the same text field?
I don't have any iLogic experience, but is this something that would be better done with iLogic?
Thanks in advance.
